Removing TPS sensor
Old Jun 14, 2007 | 08:06 AM
kornerk12's Avatar
Default Removing TPS sensor
How do you remove the tps sensor from the stock TB to use it on an aftermarket TB ?
Old Jun 14, 2007 | 10:14 AM
Finest's Avatar
Default Re: Removing TPS sensor (kornerk12)
If it's riveted in place, you need to drill the rivets out.
Old Jun 14, 2007 | 10:31 AM
Hawkze_2.3's Avatar
Yep, either drill out the bolts without heads, or you can cut a little slot into the bolt and unscrew it with a Phillips head bit.
Old Jun 14, 2007 | 04:08 PM
borat's Avatar
It's a TPS, not a TPS sensor (throttle position sensor sensor?)
Old Jun 14, 2007 | 04:42 PM
mgags7's Avatar
Default Re: Removing TPS sensor (borat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by borat &raquo;</TD></TR><TR><TD CLASS="quote">It's a TPS, not a TPS sensor (throttle position sensor sensor?) </TD></TR></TABLE>
thanks for the necessary post.
OP: use a dremel to cut slots in the rivets, then use a flathead screwdriver to screw them out. Or you can just drill the heads off of them.
Old Jun 14, 2007 | 06:45 PM
kornerk12's Avatar
Default Re: Removing TPS sensor (mgags7)
and to install it....can u just use a small screw. Anyone know thread pitch and size ? I can figure it out but if someone has it already it would be helpful.
Old Jun 15, 2007 | 04:01 AM
flyrod's Avatar
If you slot the screws, then you can reuse them. Otherwise I think it's a regular M5.
cryingsuns
Mar 20, 2011 01:13 PM
EFRue57
Sep 17, 2005 05:41 PM
ndlyng
Sep 1, 2005 10:28 AM
PrettyLakesBoy
Mar 15, 2005 03:21 PM
Luserkid
Dec 9, 2004 02:24 PM
