problem?
Old Jun 15, 2007 | 09:44 PM
vteclude07's Avatar
Default problem?
2 weeks ago I let a newb drive my car. We were going on the highway and the IDIOT drops it into 2nd gear at 80 mph. I seen the rpm gauge go into a complete circle all the way to zero. Few days later the timing belt snaps. I dont think it skipped timing because when we put the new timing belt on it started right up without adjusting the cams or the crank. Before everything i took it to track and did 15.1 stock. Right after the timing incident i could barely do 15.8.
Old Jun 15, 2007 | 10:21 PM
HenryTypeS's Avatar
Default Re: problem? (vteclude07)
NEVER let a newb drive a lude.
the clutch and trans on a lude is alot different from ur everyday stick shift. (as you may kno). and since ur belt snapped. i think u MIGHT have a bent valve
Old Jun 15, 2007 | 10:29 PM
vteclude07's Avatar
Default Re: problem? (HenryTypeS)
how would i know if its bent or not..
Old Jun 15, 2007 | 10:33 PM
HenryTypeS's Avatar
if you have a misfire, thats one sign. do you have a CEL at all?
but... now that i think of it... ur friend could have just really effed up ur clutch
Old Jun 15, 2007 | 10:43 PM
vteclude07's Avatar
right after when he droped it the car started shaking badly.. i drove it like that for couple days and check engine light comes on. i take it to shop to have it checked. it says cylinder 1 misfire, after the belt snaps me and a friend take everything off, we see that the timing belt snapped and the balance shaft belt. there wasnt any belts there at all, it was all in powder. later we find out that it tore the crank sensor cables. it broke both magnets. so that cost me alot also. whats with the cylinder 1 misfire???
Old Jun 15, 2007 | 10:51 PM
HenryTypeS's Avatar
this is almost EXACTLY what happen to my friend.
it sounds like cylinder 1 is misfiring because the valve is bent.
also his car did shudder alot too.
im alost positive its the valves if not more.
Old Jun 16, 2007 | 08:45 AM
vteclude07's Avatar
well ill be looking for a new head then:/... bad thing is the car is still under payments
Old Jun 16, 2007 | 08:58 AM
nonvteclude's Avatar
do a leak down/compression test before you get a new head. you may only need to adj the valves.
Old Jun 16, 2007 | 11:04 AM
HenryTypeS's Avatar
Default Re: problem? (nonvteclude)
yeah my friend could have just got new valves. but.... the car had 170k+ so he was like. oh what the hell. lets do a JDM swap.
good luck tho. hope your able to fix it w/o trouble
Old Jun 16, 2007 | 12:15 PM
vteclude07's Avatar
ill take it to a shop and have them adjust the valves, hopefully:/.. thanks for everything
Old Jun 16, 2007 | 04:46 PM
HenryTypeS's Avatar
no prob buddy.
Old Jun 16, 2007 | 09:54 PM
nihad's Avatar
dont let kids drive your car.
haters I got
Mar 24, 2010 11:48 AM
bboynewb
Jun 11, 2008 04:38 PM
mysicivic1991
Apr 22, 2007 10:14 AM
kuja
Dec 30, 2003 10:12 AM
2kgs-R
Jul 31, 2001 12:26 PM
