PROBLEM WITH 2000 PRELUDE. HELP???
Old Jun 16, 2007 | 10:29 AM
copafeel's Avatar
Default PROBLEM WITH 2000 PRELUDE. HELP???
Hey i have a 2000 prelude that has been siting for a while. the battery kept dieing so i had to boost it few times. I would start it to let it run. Also i had someone remove my jdm fog lights. it sat for a little longer and when i went to drive it my cluster, windows and sunroof don't work. any help would be great appreciated.
Old Jun 16, 2007 | 10:32 AM
xthekidx's Avatar
Default Re: PROBLEM WITH 2000 PRELUDE. HELP??? (copafeel)
you should check the fuses. probably blown.
Old Jun 16, 2007 | 11:11 AM
HenryTypeS's Avatar
Default Re: PROBLEM WITH 2000 PRELUDE. HELP??? (xthekidx)
sounds like a fuse
Old Jun 16, 2007 | 06:37 PM
copafeel's Avatar
exactly what i thought but all fuses are fine
Old Jun 18, 2007 | 02:31 PM
copafeel's Avatar
Old Jun 18, 2007 | 09:12 PM
mattsnooz's Avatar
Default Re: (copafeel)
short circuit. The power wire for your dash and components is shorting to ground? Id check the wiring of your fog lights and make sure some wires aren't joined or touching your frame for starters
Old Jun 20, 2007 | 03:19 PM
copafeel's Avatar
thanks i will
Old Jun 20, 2007 | 03:33 PM
mattsnooz's Avatar
any luck?
funny nickname btw heh
Old Jun 20, 2007 | 08:01 PM
copafeel's Avatar
i had a quick look i really have no idea what i'm doing so no luck.
Jnkgrce
Sep 14, 2018 09:10 PM
qb1291
Apr 16, 2011 10:35 AM
sdtypek20ac5
May 8, 2005 09:32 PM
