fuel system help please
Old Jun 13, 2007 | 08:46 PM
4thgenner's Avatar
Default fuel system help please
hi guys.
got a problem. just dropped a new built motor into my 1995 VTEC. bottom end assembled by laskey racing, stock head, nothing major. we tried to fire it up today after going over everything and it just wouldn't go. car cranks fine, but doesn't even want to try to catch.
we verified spark, there is fuel pressure at the fuel rail, but we found that the injectors were not opening. not even pulsing. checked voltage at the injectors and not getting the reference signal we should be getting. we traced 2 connectors on the passenger side of the car and the helms told us they were TDC (green plug) and CRANK POSITION (grey plug). i thought those were in the distributer for OBD1? can not find a place for them to plug into anywhere. since the injectors don't have a reference signal, of course they are not opening. its the only thing holding me back from being tuned. any ideas?
Old Jun 14, 2007 | 03:56 AM
mattsnooz's Avatar
Default Re: fuel system help please (4thgenner)
don't you just have to use the distributor with those sensors inside?
what distributor are you using with your setup?
Old Jun 14, 2007 | 07:17 AM
4thgenner's Avatar
Default Re: fuel system help please (mattsnooz)
complete obd1 h22a1 engine.
obd1 dizzy
Old Jun 14, 2007 | 07:59 AM
4thgenner's Avatar
im stumped to why the injectors won't pulse. even had a spare injector laying around and hooked up the clip to it while other one was in the rail. no pintle action from cranking. so its not the injectors themselves.
Old Jun 14, 2007 | 11:31 AM
nonvteclude's Avatar
its a shot in the dark but is the resistor box fried.
Old Jun 14, 2007 | 01:41 PM
4thgenner's Avatar
doubt it, car was running when motor was pulled. motor back in and no injectors. worth a look i guess though.
Old Jun 14, 2007 | 06:46 PM
Rosko's Avatar
Default Re: (4thgenner)
main relay?
Jmunk
Feb 17, 2006 10:09 AM
contentious
11
Oct 28, 2005 12:04 PM
db8sedan
Aug 29, 2005 09:14 AM
b16awarrior
28
Sep 20, 2002 05:26 PM
speedjunkeez
Jun 21, 2001 12:11 AM
