what this cel code
Old Dec 9, 2010 | 09:59 AM
crazes's Avatar
Moderator
Default what this cel code
Ok guys I know I am going to get smashed for this but, i cant figure out what damn cel i am looking. I know it should be the abs light but i dont know if I also looking at a different code also.
Just help me out guys and dont kill me to bad.
http://www.youtube.com/watch?v=ZnrajQYb2wE
Old Dec 9, 2010 | 11:21 AM
1GPlusSH's Avatar
Default Re: what this cel code
2 or 12...
i've never seen one blink like that, though
Old Dec 9, 2010 | 12:33 PM
crazes's Avatar
Moderator
thats why i am tripping cause i can't figure it out. Normally the engine light is what would blink long and then short but i don't if its thats the way the abs cel indication works.
Old Dec 9, 2010 | 12:52 PM
Kronn 98SH's Avatar
Does it repeat? Leave the key to ON a little longer and take another vid. Then I can tell you for sure.
And of course, then I will smash you.
Old Dec 9, 2010 | 12:53 PM
ludeman69's Avatar
there are different codes for the abs system and that is code number 2. i think so anyways
Old Dec 9, 2010 | 12:55 PM
AyOhOndA's Avatar
never seen that b4. looks like the car gremlins are at it again.
Old Dec 9, 2010 | 03:08 PM
LUDEcidDream's Avatar
x2
it looks like it is a code 2 to me.. which would be the second oxygen sensor
EDIT: all the codes u need
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
check it homie
Last edited by LUDEcidDream; Dec 9, 2010 at 03:13 PM. Reason: could be helpful for the dude
Old Dec 9, 2010 | 03:42 PM
minilogoguy18's Avatar
^No offense but I'm sure crazes knows the codes by heart at this point in his honda days. Looks like code 2 to me too but do what Kronn said and leave the key on, it will keep blinking the code over and over til you can clearly see what it is.
Old Dec 10, 2010 | 05:46 AM
crazes's Avatar
Moderator
ok ok so i wait a lil longer here what happened
http://www.youtube.com/watch?v=x0bj2AFP-_4
Old Dec 10, 2010 | 05:54 AM
crazes's Avatar
Moderator
thanks man.... at least he has the right intentions to help but he is new and doesn't know about my motor or anything
Originally Posted by LUDEcidDream
x2
https://honda-tech.com/forums/showthread.php?t=978933
check it homie
thanks for try but the problem is i only have 1 oxygen sensor
Old Dec 10, 2010 | 06:50 AM
Weird, only does it once, only thing I can make out is ABS code 1. Do you get a stored CEL while driving?
Old Dec 10, 2010 | 08:47 AM
crazes's Avatar
Moderator
nope the light comes out after I start driving and then stays on..
Old Dec 10, 2010 | 09:16 AM
Kronn 98SH's Avatar
WTF is up with your clock?
Old Dec 10, 2010 | 10:27 AM
crazes's Avatar
Moderator
hahaha.... yea i know its weird. its just started a few weeks ago and haven't figured out what it is... idk know and really never cared to find out what happened right now? I think its a short in it. Are you able to help me figure out what code it is?
Old Dec 10, 2010 | 12:04 PM
AyOhOndA's Avatar
Could it be a short or a loose connection? I've never seen the cel do that, but I think they're right about the ABS.
Old Dec 10, 2010 | 12:24 PM
Kronn 98SH's Avatar
I think your clock might be related to your CEL. Since the flashing doesn't repeat, it's not a code. Possibly two different shorts or one short causing both problems.
Old Dec 10, 2010 | 02:35 PM
crazes's Avatar
Moderator
but it does blink twice the same way though on the abs. IDK man wtf
Old Dec 10, 2010 | 02:55 PM
jkoni426's Avatar
Is the abs light on constantly when you drive? Are you pushing down the brake pedal when you turn the key?
I'm thinking you're in the dtc delete mode for the abs maybe...
Old Dec 10, 2010 | 06:54 PM
Kronn 98SH's Avatar
I'm going with short. Have you pulled the fuse yet?
Old Dec 11, 2010 | 04:52 AM
crazes's Avatar
Moderator
it starts after i start driving. thought it might be the sensor so i made sure i cleaned it well and changed out the left axle and there is a light when i start driving.
no i am not pushing the pedal when i turn the car on it stick dont need to do that.
i did pull the fuse and the battery terminal. then i drove it and took the video after.
if its a short i guess pull the clock and see whats up but i dont remember if i need to pull entire dash for it or can just the clock come out. I got to check my helms and all data to see what i need to do for it.
Old Dec 11, 2010 | 03:18 PM
AyOhOndA's Avatar
The clock is in one big piece with all the warning lights/gas/temp.
Old Dec 13, 2010 | 04:03 AM
1GPlusSH's Avatar
what were the last couple of things you've done to your car before this started happening? it doesn't matter how small...ANYTHING
serjey15
Feb 6, 2011 08:11 PM
eg_boi
Aug 4, 2008 01:12 PM
Wpgjets
Mar 6, 2006 05:11 AM
quazar
Jul 13, 2004 06:53 PM
Nuts
Apr 22, 2004 05:24 AM
