h22 not starting?
Old Dec 1, 2010 | 08:04 PM
motormike40's Avatar
Default h22 not starting?
I had a set of fuel injectors die on me, so I used 2 different sets of dsm 450's with the resistor box correctly wired up. I'm getting spark, I pulled the wires and put plugs in it and turned it over and they were arcing. I'm getting fuel, when I pulled the plugs they were wet. I also check the three grounds on the motor and trans. The only possible thing I could think of is that my resistor box has died? I got it to turn over once and only once, and it sounded like it was on 2 cylinders. I check and rechecked the firing order. I'm running a jdm h22 with skunk2 pro 1 cams I/H/E with dsm 450's with a phearable.net chip, which is set up for the dsm's. What else could be preventing it from starting?
Old Dec 1, 2010 | 08:21 PM
Default Re: h22 not starting?
There's also no check engine lights.
Old Dec 2, 2010 | 03:29 AM
patbb2's Avatar
i have a 94 lude with a h22a1 swap and mine had a simular problem. ended up being 1 of 3 modules inside the distributor. i took the module out of an accord distributor and its run perfect ever since.
Old Dec 2, 2010 | 05:37 AM
The Icm, located inside the dist? My understanding I can unbolt them and swap them out.
Old Dec 2, 2010 | 05:49 AM
1GPlusSH's Avatar
how are your plugs firing if you don't have fire from the distributor?
Old Dec 2, 2010 | 06:33 AM
nus_dogg's Avatar
What's the plugs wet from? Oil or Fuel?
Old Dec 2, 2010 | 08:46 AM
I'm getting fire from the distributor, if the coil or icm goes out will that cause a weak spark?
Old Dec 2, 2010 | 08:47 AM
Fuel.
Old Dec 2, 2010 | 03:07 PM
The resistor box had took a **** on me.
Old Dec 3, 2010 | 04:14 AM
1GPlusSH's Avatar
nothing like a cleveland steamer
lil91hatch
Apr 18, 2010 09:38 AM
93Hammer
Dec 11, 2008 04:10 PM
jamey220
Mar 19, 2005 12:36 PM
ShowSi2
Dec 9, 2003 05:27 PM
