Old Dec 5, 2010 | 11:50 AM
guza's Avatar
Default :(
Soooooo....ummm hey i was wandering if anyone out there lend me some advice, i have a 98 lude, and i did a paperclip jumper test for my check engine light and it read off these three codes yeah theres alot wrong with my car
65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
70 Automatic Transmission malfunction with the automatic transmission controls
not to mention i cant even get to high enough revs to activate my vtec, i think theres also something wrong with my ecu and it when this happened it wouldnt let me go passed 4k rpms and i was flooring it and was only going like 40 mph i think that might be called limp mode but im not sure, but whatever the case this sucks and im venturing itll be alot of money to fix it soooo any advice would be worth having,
Old Dec 5, 2010 | 12:09 PM
minilogoguy18's Avatar
Default Re: :(
With your CEL's you shouldn't under any circumstance being 'flooring it' the ecu is keeping you from using vtec so you don't F things up even further.
65 is obvious, get a new heated O2 sensor
45 could be a few different things, possibly injector, get a helms and follow the troubleshooting chart
70 more than likely transmission failure, the auto transmissions that came in the 5th gen is the worst auto trans honda has ever built, might be time to swap to manual.
Well kinda take that back about being badly made, triptronics were very new at the time, mostly why they don't last.
Old Dec 5, 2010 | 12:15 PM
guza's Avatar
Default Re: :(
ooh ok thanks ^^ yeah i wasnt sure what was going on when it happened and i was trying to get out of the way when i was driving and i tried to go faster (aka flooring it) and it didnt go any faster lol, I just had the transmission rebuilt like almost a year ago, dunno if i can afford another trany much less a swap to manual, i wish i can change it to a five speed that would be bad ***
Old Dec 5, 2010 | 02:14 PM
Default Re: :(
You had the same one rebuilt? Who did it? Honda dealers don't even rebuild auto transmissions anymore, costs too much to pay techs to do it, they just put in ones that have been rebuilt by Honda. I don't think I'll be much help about the trans problem though, I don't work on auto trans and it's been years since I've owned a car that had one.
Old Dec 5, 2010 | 06:32 PM
Kronn 98SH's Avatar
Default Re: :(
Wonderful thread title.
Old Dec 5, 2010 | 06:50 PM
ludeman69's Avatar
Default Re: :(
start with the o2 sensor then clear the codes and start over again.
Old Dec 6, 2010 | 03:52 AM
1GPlusSH's Avatar
Default Re: :(
exactly what i was thinking.
ditto. good chance the o2 sensor is your issue with the first two
Civic Racer X 7
21
Feb 20, 2011 11:43 AM
CRVTECSCREAMER
Mar 17, 2010 10:30 PM
ej8parkd
Aug 7, 2009 07:05 AM
e2000
Dec 10, 2005 11:44 AM
BoRiCuA
Nov 30, 2004 01:23 PM
