clutch issues
Old Dec 11, 2010 | 08:41 PM
92_luder's Avatar
Default clutch issues
So the past couple days wen my car is cold my clutch is really sponge like and jus today wen I got in my clutch asks as if it doesn't wanna engage and it sticks to the floor.....I'm hoping its my slave cylinder since it stuck to the floor. It wasn't gradual it kinda jus happened so I dnt think it'd b the clutch itself goin bad.
Any ideas????
Old Dec 12, 2010 | 07:09 AM
godslayer's Avatar
Default Re: clutch issues
Any ideas????
Not quite sure what you're acting?
Is the pedal staying on the floor when you push it in but then returning really slowly? Likely your master cylinder. Check the slave out too. Could just need a good bleed but parts are cheap and worth replacing as if the cylinders do go out you'll be stranded wherever it happened.
Old Dec 12, 2010 | 07:23 AM
crazes's Avatar
Moderator
i had the same issue and required for me to pump it to build pressure. I replaced my master and it was good to go. Also just make sure that when you bleed the system that you make sure your slave bleeder nut is tight
Old Dec 12, 2010 | 07:08 PM
92_luder's Avatar
i replaced both the master and slave....i been bleeding it for about a hour n my pedal falls to the floor....my hydraulic system isnt building any pressure at all....
Old Dec 12, 2010 | 07:18 PM
ml21's Avatar
Crack the bleader and pump a couple times and dont forget to fill the resivour with fluid eventuly you will get pressure it take awhile after you replace the slave and/or master.
Old Dec 12, 2010 | 08:37 PM
crazes's Avatar
Moderator
make sure all the lines are tight. Also make sure you bench bleeded the master cylinder and the slave cylinder also. Last thing make sure all lines are tight resiovur is full when bleeding. If it still not building pressure take some teflon tape and put it on the bleeder of the slave to make sure no air is getting in there at all.
Old Dec 13, 2010 | 02:33 AM
godslayer's Avatar
What possible good can come from "bench bleeding" and open hydraulic circuit?
Old Dec 13, 2010 | 09:10 AM
crazes's Avatar
Moderator
one you make sure that the part you bought is working properly and makes bleeding the system 1000x faster since you dont have to bleed fluid throught both parts instead just the lines
Old Dec 14, 2010 | 10:35 AM
92_luder's Avatar
got it figured out, i bled the master cylinder first and its pumpd fine after that. is it naturally for my clutch petal to stick to return slower in colder temps?
Old Dec 14, 2010 | 11:19 AM
crazes's Avatar
Moderator
not really. It has to be really cold for it to come up slowly. Just make sure you might not have a kink or anything in the lines at all
Old Dec 14, 2010 | 02:11 PM
godslayer's Avatar
I'd guess you still have air in there...
Old Dec 15, 2010 | 10:35 AM
92_luder's Avatar
yeah thas wht i figured...ill bleed it again on my off day. Thanks for all the assistance
blacklabel14
Feb 3, 2011 12:32 PM
Greenery18
Jul 8, 2005 04:22 PM
DriveSideWays
Aug 27, 2004 05:06 PM
FLCivic
Jun 30, 2004 03:48 PM
