help
Old Nov 13, 2010 | 04:28 PM
accord2civic2prelude's Avatar
Default help
when i connect the negative battery terminal, the fuel pump primes and the gauge cluster comes on as if the key was in.
Old Nov 14, 2010 | 07:54 AM
Acidcrakker's Avatar
Default Re: help
Tough one there, maybe its a bad ignition switch?
Old Nov 14, 2010 | 11:28 AM
Default Re: help
when i unplug the ignition switch from the harness, it still happens. even with all 3 harness plugs the cluster has power. only when the middle plug is plugged in does the fuel pump prime
Old Nov 14, 2010 | 06:51 PM
Default Re: help
UNder the dash fuse box or under hood box might have a short
95gsrEG
May 20, 2016 10:26 AM
SinsEvil666
Jan 11, 2009 10:44 PM
jaydmtim
Nov 29, 2007 07:51 PM
whiteef-8
16
Feb 24, 2005 05:45 AM
undefinedcrx
Feb 19, 2004 01:48 AM
