shifting problems...
Old Jul 14, 2004 | 10:19 AM
Inextricabledrvr's Avatar
Default gears feel difefrent??
The other day i shifted hard into 3rd and it felt like somethin popped when it went in. Now my 1st, 3rd, and 5th gears feel a little spongy meaning that it is really easy to put in, but my 2nd, 4th and reverse feel perfectly fine. and it drives perfectly fine, it just feels weird going into those upper three gears.
What could be the problem here?
shift fork?? linkages?
thanks any info would be great
Modified by Inextricabledrvr at 12:47 PM 7/14/2004
Modified by Inextricabledrvr at 2:54 PM 7/14/2004
Old Jul 14, 2004 | 10:48 AM
CHK4TIX's Avatar
Default Re: shifting problems... (Inextricabledrvr)
It sounds like you might have bent the shift fork or your sycros just **** the bed. you could try switching out the fluid, but I really doubt that will do anything. You most likely will just have to pull the tranny and check it out.
Old Jul 14, 2004 | 12:29 PM
Sephro's Avatar
Default Re: shifting problems... (CHK4TIX)
yeah sounds like synchros to me too. If you do decide to change out your fluid you could try using synchromesh MTF. It might buy you some time at the very least.
Old Jul 14, 2004 | 01:19 PM
Default Re: shifting problems... (Sephro)
thanks guys
dont get me wrong, but if my synchros are bad will i be able to shift into those gears?
Old Jul 14, 2004 | 01:30 PM
4bidden's Avatar
Your shift cable is busted, you'll need to replace it/them.
Yes, I'm that sure.
But first check that all the metal clips that hold the linkage in place are still there. There are 2 by the transmission and 2 at the front of the shifter base plate.
Old Jul 14, 2004 | 01:38 PM
Default Re: shifting problems... (4bidden)
is this covered under warranty? ive had the car only a few months and i purchased the extended warranty so im hoping this is covered.
thanks any info would be great..
Old Jul 14, 2004 | 01:39 PM
4bidden's Avatar
It likely would be. Its not something that should have broken that quickly.
Old Jul 14, 2004 | 01:54 PM
true...they have replaced it before...
thanks for the info
NOOdS
Apr 20, 2009 11:04 AM
sdr85
Dec 6, 2007 11:54 PM
HondamanXxX
Sep 21, 2007 06:34 PM
JDM4DRACCORD
May 23, 2005 09:03 AM
4gen
Aug 11, 2004 04:29 PM
