abs pump overrun error
Old Jul 12, 2004 | 11:58 PM
quazar's Avatar
Default abs pump overrun error
Does anyone know what that means? Does that mean that the pump is bad?
Old Jul 13, 2004 | 03:24 AM
pentaq's Avatar
Default Re: abs pump overrun error (quazar)
I think it may help.
Old Jul 14, 2004 | 12:13 AM
quazar's Avatar
Default Re: abs pump overrun error (pentaq)
SOmeone told me that a 1 code is the o2 sensor. Could that be right?
Also, the scematic you gave me says in the first page..."with the engine running and abs light on"....referring to jumping the abs connector. Do you get the same code when it is off? Because that is when I pulled the code. After the car was turned off.
Thanks so much for your help.
Old Jul 14, 2004 | 01:33 AM
pentaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quazar &raquo;</TD></TR><TR><TD CLASS="quote">SOmeone told me that a 1 code is the o2 sensor. Could that be right?
Thanks so much for your help.</TD></TR></TABLE>
Yeah code 1 is for O2 sensor but when MIL light blinks not ABS light. It's totally different thing.
It shouldn't matter. There should be the same code if you shorten the connector and start engine.
tobytigger
Jun 23, 2015 04:31 PM
DC2-JRSC'd
May 24, 2011 09:58 PM
billdrah
Sep 26, 2009 11:47 AM
iRIDEdumped
Jul 11, 2007 06:12 PM
southpole12
Oct 13, 2004 09:56 AM
