radio problem
Old Jul 12, 2004 | 02:40 PM
dc5r2002's Avatar
Default radio problem
I recently installed a new cd player in my 95 lude replacing my stock tape player, since I just did this less then 24 hours ago my keyless entry no longer is working and now the cd player doesnt work, it seams these both happened at the same time. I am wondering if the anti theft radio thing will affect the opperation of the radio, I am thinking it wouldn't but then again i have heard of weirder electrical problems. Any help or feedback is apprieciated.
Old Jul 12, 2004 | 02:46 PM
CHK4TIX's Avatar
Default Re: radio problem (Pulp Fiction)
Well, on the 95, i pretty sure that the locks and radio have nothing to do with each other. Did you use a wire harness or did you cut and splice the radio in? I would take the radio out and verify all of the connections. Also check the fuses maybe you grounded something out when you were putting it in.
Old Jul 12, 2004 | 02:52 PM
dc5r2002's Avatar
Default Re: radio problem (CHK4TIX)
All fuses are ok I just got done checking and yes I used a harness (not a butcher here) I sodered all the connections so I doubt they are bad.
Old Jul 12, 2004 | 04:05 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
95 radio has nothing to do with keyless unless somehow a +12V cable was shorted. Did you check fuses under dash AND under hood?
Old Jul 12, 2004 | 04:14 PM
AndyD's Avatar
The theft feature is part of the radio, not on the car. That has nothing to do with your problem.
Does your clock still work??
Old Jul 12, 2004 | 05:06 PM
dc5r2002's Avatar
Default Re: radio problem (AndyD)
well something in the radio is messed up i checked all the fuses and ended up testing each port on the conector where i found out they all had power, the fuse on the back of the radio is ok so something else muct be wrong, BTW the stock radio works
Old Jul 12, 2004 | 05:12 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pulp Fiction &raquo;</TD></TR><TR><TD CLASS="quote">well something in the radio is messed up i checked all the fuses and ended up testing each port on the conector where i found out they all had power, the fuse on the back of the radio is ok so something else muct be wrong, BTW the stock radio works</TD></TR></TABLE>
Then the fuse under the hood for your stereo works fine.
Maybe incorrect wiring of the stereo?? Crossed wires??
Old Jul 12, 2004 | 06:52 PM
dc5r2002's Avatar
no it is all correct i am 100% positive i have been going to school for automotive technology for the past year, electrical stuff was a huge part, everything is wired correctly it is a radio itself i am 100% sure
slwh22accord
Honda Civic (2001 - 2005)
Oct 17, 2006 07:30 AM
Manolo
Audio / Security / Video
May 15, 2006 02:25 PM
xSCTYGx
May 31, 2004 08:44 AM
damion911
Mar 3, 2004 11:14 AM
