Automatic to manual conversion
Old Jul 13, 2004 | 04:38 AM
92whiteSi's Avatar
Default Automatic to manual conversion
I am soon to be doing a complete swap in a 92 si auto to a jdm h22 with a 5speed tranny and i want to know exactly everything i need to do the swap so if you have info or have dont this before it would much appreciated if you could leave me some info or if you have it a step-by-step or a walkthrough or a link to one on the internet. I will be pulling the old h23 in about a week or so and ordering the engine and tranny then and from the time i order it till it gets here i want to have the clutch pedal assembly and all that stuff done so it will drop in and drive. If you have any knowledge or know anyone who does i would sure appreciate it if you could help me out. TY and please reply
Old Jul 13, 2004 | 06:16 AM
H23 Power's Avatar
Default Re: Automatic to manual conversion (92whiteSi)
http://www.extremeredline.net/....html
this is a writeup I did for my 91 accord....its about 98% compatible with the 92-96 lude because most of the parts are the same.
Old Jul 13, 2004 | 06:37 AM
CarpAngler's Avatar
Default Re: Automatic to manual conversion (H23 Power)
i have a lot of the parts if you are interest most are new. Have all the little pins, linkage, pedals, etc no clutch flywheel or tranny. Most of part are new from the dealership let me know will set for very cheap.
Old Jul 13, 2004 | 02:33 PM
92whiteSi's Avatar
Yeah lude975 i will have the big parts like the tranny, clutch, flywheel, and linkage and shifter most likely, i would need the master and slave cylinders and the pedal setup if you could help me out it would be much appreciated and about how much do u need for the parts you have?
Old Jul 15, 2004 | 06:58 AM
CarpAngler's Avatar
Have 2 slave cylinders, flywheel cover, master cylinder reservoir, 2 slave cylinders, shift linkage and all little bolt and pins for it, brake and clutch pedals, clutch switch, pedal brackets, new throttle cable, there is a bunch more. It is basically all the little stuff needed for the swap and is all new except the slave cylinders and master cylinder reservoir. The rest if all from the honda. It is around $500 worth of parts. Will throw in h23 valve cover and energy suspension rear mount insert for nothing. Email me or im me at joshm3357 if you wanna work something out.
Old Aug 12, 2004 | 12:35 PM
92-LS-Civic's Avatar
Default Re: Automatic to manual conversion (lude975)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude975 &raquo;</TD></TR><TR><TD CLASS="quote">i have a lot of the parts if you are interest most are new. Have all the little pins, linkage, pedals, etc no clutch flywheel or tranny. Most of part are new from the dealership let me know will set for very cheap. </TD></TR></TABLE>
do you still have the parts. and also how much?
Marvlus_
Sep 7, 2011 12:14 PM
xXbeetleXx
Jun 21, 2008 05:25 PM
darkspector2.0
Jul 23, 2007 11:06 PM
CD8coupeSiR
Jan 6, 2006 08:58 PM
Scho
17
Dec 28, 2003 01:47 PM
