Location of engine temp. sensor?
Old Jul 10, 2004 | 10:07 AM
chattownrexer's Avatar
Default Location of engine temp. sensor?
My lude is reading hot while sitting still and I can't find the location of the temp sensor. Can U help?
Old Jul 10, 2004 | 10:39 AM
Kal's Avatar
Kal
Default Re: Location of engine temp. sensor? (chattownrexer)
I believe it is connected to the block...
Old Jul 10, 2004 | 01:06 PM
speedracer9k's Avatar
maybe you need to add coolant becuase your car is overheating...just my $.02
Old Jul 10, 2004 | 02:45 PM
jmcclell's Avatar
Default Re: (speedracer9k)
The prelude has 2 sensors located on the bottom left hand side of the cylinder head.
The 2-pin Green connector, is the coolant temperature sender used by the ECU.
The single pin sensor next to it, is used for the engine temperature guage.
You also have a coolant temperature switch on the thermostat housing, for switching the radiator fan.
JSPECHB
Nov 14, 2014 09:30 AM
busyychild
May 6, 2008 11:09 AM
Simmerman
12
Sep 18, 2007 07:05 PM
prelude-bb3
Jul 25, 2004 11:42 PM
