idle question
Old Jul 13, 2004 | 08:54 AM
socakracer974's Avatar
Default idle question
I have a 92 si 4ws. i have replaced my stock intake w/ a aem cold intake. not long after my car started idling up and down between 1000 and 2500 rpms. it goes up and then drops right away with in about a second. i need some help.
Old Jul 13, 2004 | 09:03 AM
Sephro's Avatar
Default Re: idle question (socakracer974)
Did you connect all the vacuum lines?
Old Jul 13, 2004 | 09:14 AM
delguiner's Avatar
Default Re: idle question (Sephro)
could also be your fast idle valve
Old Jul 13, 2004 | 09:16 AM
Speedra500's Avatar
Default Re: idle question (delguiner)
sounds like a fast idle valve to me too
Old Jul 13, 2004 | 01:33 PM
Default Re: idle question (Speedra500)
all the lines were connected except one. but there was no place to connect it. where can i find this fast idle valve.. thanks a lot for the info by the way
Old Jul 13, 2004 | 01:37 PM
delguiner's Avatar
the fast idle valve is under your throttle body...
sometimes whats inside gets lose, so just take it apart and screw it back in
Old Jul 13, 2004 | 01:44 PM
Sephro's Avatar
I am guessing that the one that you said there was no place to connect it to is the one that was connected right where the intake meets the throttle body?
I have heard of problems like you are having being caused by leaving that hose out. What I did was make a small hole in the rubber where the CAI meets the throttle body. Took the metal piece that hose was connected to on the stock intake and put that in the small hole you made in the rubber. Just be sure not to make the hole too big. That should fix your problem.
Old Jul 13, 2004 | 02:34 PM
Okay. the hose i didnt connect was a long hose that ran from the intake control solenoid box to the intake control diaphragm. also there is a hose that is not connected that is on top of the intake manifold but it is short and i cant find anything that would connect with it.
with the fast idle valve. it was not loose so do i still take it off and put it back on?
Iloveyourhonda92
Apr 11, 2015 07:46 PM
g0tgot
Feb 1, 2009 07:27 AM
b_serious
Jun 10, 2007 03:01 PM
dkrex001
Jul 28, 2006 04:53 PM
Metal_SOL
Nov 19, 2002 07:05 AM
