HIDs
Old Jul 11, 2004 | 09:38 AM
xsoofreshx's Avatar
Default HIDs
does anyone kno about HID's ? one of my HID's is out .... its not the bulb becuase sometimes when i move the wires and wiggle the ballast it would work but now i dont kno whats up with it . my friend is sayin i need a new ballast because its not puttin enough voltage to like up the crystals in the bulb .... i need other peoples input about this and also if i do need to get a new ballast...where do i get one ?
ricky
Old Jul 11, 2004 | 09:55 AM
Mario.'s Avatar
Default Re: HIDs (xsoofreshx)
Well, if the bulb works... then it has to be the ballast.
I would switch ballasts/bulbs and narrow down the problem.
Old Jul 11, 2004 | 10:22 AM
xsoofreshx's Avatar
thanks bro . ill give it a shot .
Old Jul 11, 2004 | 11:50 AM
Mario.'s Avatar
Default Re: (xsoofreshx)
Yea no prob. Post up your results. Also, what HID's are using? Is it a retrofit (from like an M3 or Audi, etc.) or is it an aftermarket kit?
Old Jul 11, 2004 | 07:24 PM
xsoofreshx's Avatar
im thinkin its the ballast...so how can i get it fixed or get a new one ?
Old Jul 11, 2004 | 08:33 PM
Mario.'s Avatar
I've never taken apart a ballast. Just buy a new one. And answer my last question as well.
Old Jul 12, 2004 | 11:48 AM
xsoofreshx's Avatar
i dunno where i can buy JUST 1 lolx...u kno where i can get one ?
Old Jul 12, 2004 | 12:41 PM
Mario.'s Avatar
Default Re: (Mario BA4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario BA4 &raquo;</TD></TR><TR><TD CLASS="quote">Yea no prob. Post up your results. Also, what HID's are using? Is it a retrofit (from like an M3 or Audi, etc.) or is it an aftermarket kit?</TD></TR></TABLE>
Old Jul 12, 2004 | 01:05 PM
ludetech
Guest
Posts: n/a
I really really like your sig xs
Old Jul 12, 2004 | 04:47 PM
h22 civic's Avatar
Default Re: (ludetech)
ballast
Old Jul 12, 2004 | 06:31 PM
xsoofreshx's Avatar
its aftermarket .
Old Jul 12, 2004 | 08:51 PM
Mario.'s Avatar
What brand...?
Old Jul 13, 2004 | 12:02 PM
xsoofreshx's Avatar
bohmen ballast .
Old Jul 13, 2004 | 02:23 PM
EK22snatch
Guest
Posts: n/a
yeah dude, it definately your ballast acting up. usually there's a coil of wires in there, and often after long periods of use they get worn out. you could try and fix it, but i'd say just get a new one.
Old Jul 13, 2004 | 04:53 PM
xsoofreshx's Avatar
how would i try fixing it ?
Old Jul 14, 2004 | 10:40 AM
xsoofreshx's Avatar
Old Jul 14, 2004 | 12:02 PM
Mario.'s Avatar
You don't. You buy a new one and call it a good day.
Old Jul 14, 2004 | 01:14 PM
ludetech
Guest
Posts: n/a
again xs that chick in your sig is fine
Old Jul 14, 2004 | 07:02 PM
Frankie324's Avatar
try grounding it. same thing happened to me and it running a wire from the ballast to a good ground fixed it.
Old Jul 14, 2004 | 07:07 PM
xsoofreshx's Avatar
haha thanks ludetech .
-frankie i grounded it the same as the other side and the other side works jus fine ...
Old Jul 14, 2004 | 07:10 PM
Frankie324's Avatar
KOOL, Yo do you have more and bigger pics of that girl in your sig. DAMN!
Old Jul 14, 2004 | 07:13 PM
xsoofreshx's Avatar
nah sorry dude...i reformatted my comp. so i lost everything
ill try to find her agian for u guys...gimme u guys AIM .
Old Jul 14, 2004 | 07:23 PM
Frankie324's Avatar
my aim if frankiej324.
damn, she looks mighty fine, even at 70 x 70 pixels.
Old Jul 14, 2004 | 08:31 PM
Speedra500's Avatar
Default Re: (Frankie324)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frankie324 &raquo;</TD></TR><TR><TD CLASS="quote">
damn, she looks mighty fine, even at 70 x 70 pixels. </TD></TR></TABLE>
hah, agreed
Old Jul 15, 2004 | 01:03 AM
BIGGrUmpYBUTT's Avatar
Default Re: (Speedra500)
once again to agree with everyone else, your ballast is dead, sorry to hear, you should take it out right away, if the ballast is bad, eventhough the bulb isnt lighting up, it can still send some current to the bulb and slowly killing it at night when you have your headlights on
please dont open the ballast, not only will you not be able to fix it, you might get hurt, heard there is some discharge inside that can happen and you could get shocked, and the wattage on a hid ballast is alot more than standard
alot of companies are out for a little bit, and alot just take your sale and never help you again, brightstar sells the ballast by itself if you need it, please check my post on https://honda-tech.com/zerothread?id=926420, believe the shop i go to sells them for about $90 plus shipping for ballast
but there is a couple things to warn you about, read up my post first and then read the rest of this, not all kits are made the same, one fo the reason brightstar last longer is because unlike the other aftermarket hid ballast, it lights reverse, if you notice, even with OEM setups like MBZ and BMWs, when you turn on, its really bright in beg. and then gets lower to the set brightness, brighstar in their technology to make the bulbs and everyhting last longer, it goes dim to bright, or the set brightness, so if one ballast is the older company, when you turn on your headlights, one side will go bright to low an d the other side will go low to bright
they will both look the same after warmup because the color is all based on the bulbs, and since both your bulbs are the same, after warm up it will be fine, jsut looks funny or cool, how you look at it when you turn it on
another thing is, jsut about every company uses different plugs, what ive had to do for friends because the ones who didnt get brightstar, they ahd bad ballast or bulbs, what you want to do is cut up the bad ballast and take the connecting plugs that match up to your bulbs, then cut the new ballast and correctly connect or especially sauder&lt;-- dont know spelling, the wires, jsut make sure you got the correct sides, one is usually power and one is ground, usually a color of red or something bright indicates power i believe with most kits, suggest jsut getting 2 ballast or 1 at a time when it goes out, up to you
hope everything works out
