What else would you replace?
Old Sep 19, 2006 | 02:12 AM
upallnite's Avatar
Default What else would you replace?
97 H22a (still has auto tensioner)
I have to replace the water pump, so I figured new timming belt and ballancer belt. I was thinking this would be a good time to put a manual tensioner in as well.
Any other suggestions? Cam gears?
Old Sep 19, 2006 | 04:19 AM
Lewdin' Incognito's Avatar
Default Re: What else would you replace? (upallnite)
I would say leave out the balancer belt. Just replacing the cam gear isn't going to net you anything unless you plan on tuning afterwards. Would be a good time to adjust the valves though. Timing belt and manual tensioner for sure.
Isn't it a good idea to put in a new thermostat when replacing the water pump?
Old Sep 19, 2006 | 04:50 AM
tacticalcustoms's Avatar
Default Re: What else would you replace? (Lewdin' Incognito)
n<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">I would say leave out the balancer belt. Just replacing the cam gear isn't going to net you anything unless you plan on tuning afterwards. Would be a good time to adjust the valves though. Timing belt and manual tensioner for sure.
Isn't it a good idea to put in a new thermostat when replacing the water pump?</TD></TR></TABLE>
its not necessary to change the thermostat. just t-belt,waterpump and the tensioner. I would change the front main seal also.
Old Sep 19, 2006 | 05:32 AM
mgags7's Avatar
its not necessary but its never a bad idea....**** nothing is necessary....
get new balance seals and the retainer if you dont already have it....
Old Sep 19, 2006 | 06:30 AM
upallnite's Avatar
I planed on the thermostat.
The main seal was a good idea. I didn't think of that.
I will look in to leaving off the ballancer belt. Not sure if I want to do that or not.
Old Sep 19, 2006 | 09:29 AM
MadCityLude
Guest
Posts: n/a
Ditch the balance belt. It a waste of power.
Old Sep 19, 2006 | 09:35 AM
mgags7's Avatar
its like 2whp.....i left mine
my brother's civic/h22 has super hard mounts and without the balancers working it was super rough and EVERYTHING rattled inside....
Old Sep 19, 2006 | 09:40 AM
MadCityLude
Guest
Posts: n/a
Default Re: (bb4ever)
If your running aftermarket mounts you will feel it much more than with stockers. So if thats the case then maybe you would wanna leave it on.
Old Sep 19, 2006 | 09:41 AM
MadCityLude
Guest
Posts: n/a
Default Re: (MadCityLude)
Personally, I am running polyfilled DIY mounts and the little extra vibration doesn't bother me.
Old Sep 19, 2006 | 11:01 AM
92blkJDMh22's Avatar
some girls even like the extra vibes..... just saying........
nothing leads to erotic driving situations more than firm motor mounts and a lack of balancer shafts...... and you can quote em on that
Old Sep 19, 2006 | 06:41 PM
mgags7's Avatar
geez, just reading that is making my motor mounts firm
Old Sep 19, 2006 | 06:43 PM
MadCityLude
Guest
Posts: n/a
^^^ You sick bastard!!
lmao
Old Sep 20, 2006 | 02:25 AM
upallnite's Avatar
Default Re: (92blkJDMh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92blkJDMh22 &raquo;</TD></TR><TR><TD CLASS="quote">some girls even like the extra vibes..... just saying........
nothing leads to erotic driving situations more than firm motor mounts and a lack of balancer shafts...... and you can quote em on that</TD></TR></TABLE>
I have soft stock mounts. I am going to try removing it for a little bit. If I don't like it then I can always put it back on.
As for the girls, F'um. Litterally.
Thanks for the suggestions and hummor everybody.
Motoer head
Jan 31, 2012 04:32 AM
realis9
Aug 26, 2007 12:05 AM
tmrtwo
Jun 24, 2007 10:49 AM
98TypeSH
Feb 13, 2006 08:58 PM
