Clutch Adjustment
* B A N N E D *
Clutch Adjustment
okay, so the SH i'm picking up has had an aftermarket clutch and lightened flywheel installed, the clutch engagement point is nowhere near stock, is this normal? I barely have to move my foot at all when letting it out and the clutch is fully disengaged, is there any way to adjust this? new clutch springs?
moderator emeritus
Re: Clutch Adjustment (InitialJRift)
u mean fully engaged...as in the clutch engages close to the pedal floor?
mine does the same thing. I adjusted the clutch pedal and it made it a little better. Its the pressure plate that does this. Not really any way to change it without changing the pressure plate.
Try bleeding the clutch. It may help some. Also be sure that your master and slave cylinders are not leaking.
Re: Clutch Adjustment (98vtec)
yeah samee thing to me i berly have to press clutch and it doesnt grib as good and bleeding clutch? tell me how to do it ill might do it on weekends
