calibration
Old Sep 12, 2006 | 11:28 AM
pizzamanprelude's Avatar
Default calibration
anybody know were i can get a decent hondata calibration for a 5th gen running bolt ons. something to get me started...again
Old Sep 12, 2006 | 11:32 AM
98vtec's Avatar
moderator emeritus
Default Re: calibration (pizzamanprelude)
http://www.hondata.com
Old Sep 12, 2006 | 11:36 AM
Default Re: calibration (98vtec)
if you look at that you'll see i've already been there, the guy i was talking to set me up with a calibration but it just seems a little off, then i found out it started life as a GSR base. just wondered if anybody had anything lying around on the hard drive like a standard H22 map or slightly tweaked one that they could let me see
Old Sep 12, 2006 | 12:26 PM
bump
Old Sep 12, 2006 | 12:37 PM
kulrevon's Avatar
I know the s300 basemap for the h22 was the one labeled accord.
Old Sep 12, 2006 | 12:40 PM
Default Re: calibration (kulrevon)
whats it called, ecu wise, all the calib's i have are labelled by there ecu, i dont have one labelled accord
Old Sep 12, 2006 | 01:59 PM
soundbomber's Avatar
p13?
Old Sep 12, 2006 | 10:36 PM
Default Re: calibration (soundbomber)
it doesn't have p13 in the calib folder, do any of you guys have the accord/prelude base map, i must have an older version of smanager or sumthing because the only thing i have for a prelude is one that is for a JDM H22a running 450's and i dont trust it because my motor came with 290's to begin with. anyone help me out?
Old Sep 12, 2006 | 11:36 PM
Rosko's Avatar
you can do some math to scale down injector size if thats all that is different.
Old Sep 13, 2006 | 04:46 AM
Default Re: calibration (Rosko)
i could do that but it would probably still be wrong, the stock injector size is set to 310 or sumthing and then it says current injector size 450 so it multiplies it itself, i would think there are some key differences that would be different between the JDM h22 and my 5th gen. i wanted to get stock timing and stock fuel maps so that i could work from there
Old Sep 13, 2006 | 12:52 PM
bump anyone
Old Sep 14, 2006 | 01:46 AM
come on, some one has to have either a stock prelude map or that accord map that the guy mentioned before.
Old Sep 14, 2006 | 03:22 PM
roller3804's Avatar
I have one. I can send it to you check ur pm
Prudz_lude
Apr 1, 2010 09:43 PM
mattmw88
Sep 17, 2004 09:20 AM
92JDMSiR
May 31, 2003 08:18 PM
00CIVICwB18C1
Nov 12, 2002 07:18 PM
