slow acceleration\deceleration jerking help(automatic)
Old Sep 12, 2006 | 11:50 AM
gpupp's Avatar
Default slow acceleration\deceleration jerking help(automatic)
this slow acceleration\deceleration jerking is getting quite annoying...it only jerks into gear on street slow acceleration\deceleration but shifts smoothly when driven fast....it isn't slipping...it shifts properly in each gear just with a jerk...seems like the acceleration and gear engagement points aren't lining up...
just had the tranny flushed, cap and rotors replaced, new air filter, new spark plugs and wires, professionaly cleaned fuel injection system, oil changed.
94 prelude si automatic
90k
Old Sep 12, 2006 | 02:33 PM
Chuckles99SH's Avatar
Default Re: slow acceleration\deceleration jerking help(automatic) (gpupp)
The weak link of the prelude is the auto tranny. It is probably warning you that it is about to poop out.
Old Sep 12, 2006 | 02:56 PM
hamadiscool's Avatar
Default Re: slow acceleration\deceleration jerking help(automatic) (Chuckles99SH)
I am pretty sure that the 4th gen auto tranny was just fine, its the 5th gen that was pure evil ...I think if anything its cause u got ur tranny flushed. Honda transmission arent suppose to get flushed cause of some filter or something yaddayadda. So i am not sure about this but its probably cause u got ur tranny flushed. Good luck with it
Old Sep 12, 2006 | 03:35 PM
gpupp's Avatar
it was jerking before the flush..took it to honda and they said that should cure the problem...which it did for about a month...then it's back to sqaure one...weird.
Old Sep 12, 2006 | 05:56 PM
Default Re: (gpupp)
maybe u should have just changed the transmission oil instead of the flush...iono. Like i said though...Goodluck
Old Sep 12, 2006 | 07:43 PM
Attaus's Avatar
I've found the 4G Lude autobox to be pretty strong.. I was surprised. I dropped it from 5k before (which was incredibly stupid, I know -- I didn't care) and stayed strong. It might be going out though.. eh.
Anyone know what size the torque converter is? I'd be interested to see what will fit.
Old Sep 12, 2006 | 07:47 PM
99LudeDude's Avatar
Default Re: slow acceleration\deceleration jerking help(automatic) (hamadiscool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool &raquo;</TD></TR><TR><TD CLASS="quote">I am pretty sure that the 4th gen auto tranny was just fine, its the 5th gen that was pure evil ...I think if anything its cause u got ur tranny flushed. Honda transmission arent suppose to get flushed cause of some filter or something yaddayadda. So i am not sure about this but its probably cause u got ur tranny flushed. Good luck with it </TD></TR></TABLE>
Bullshiat it isn't supposed to be flushed. That is why the 5th gens auto tranny craps out; because people don't get em flushed. There are guys running 180K + miles on 5th Gen auto trannies because they get them flushed every 15K.
Old Sep 13, 2006 | 05:22 AM
gpupp's Avatar
could be torque convertor...just figure maybe there was something i could clean out before tearing apart the transmission...
Old Sep 13, 2006 | 07:02 AM
f22builder's Avatar
Default Re: (gpupp)
My manual says:
CHeck air filter
check PCV valve
check fuel filter
if fuel filter good check fuel pump...turn on car to start position and listen for whinning noise when you put head on center console in back..get friend to help you.
check EGR system
then change tranny fluid if you feel like it is the same
Old Sep 13, 2006 | 07:11 AM
gpupp's Avatar
thanks f22 for the manual:
air filter new
fuel filter good
???check valve maybe bad due to hard start(thinking fuel pump is dumping all the fuel back)
???egr system needs to be checked
tranny fluid was just changed
AudioFunk
Apr 16, 2014 05:06 PM
biboy
Oct 30, 2009 10:13 PM
HondaPrelude7
Jan 30, 2005 12:09 PM
brabbit
Oct 19, 2003 10:09 PM
Turbo_Man
Jan 15, 2003 05:02 PM
