swapped my h23 trani for an h22 trani have a few ?s........
i swapped out my h23 trani for an h22 into my eg hatch(has an h22a) well i have a few ?s are the vss the same ? seems that the h22 one is longer ( i used the h23 one and now my vss isnt working) also are the slave cylnders the same? i used the one that was in the car but i had to drive the holes out a bit to make it fit... over all the swap went ok just the trani makes a noise when the clutch isnt put in and the vss isnt working.. anyone know? also how many quarts of fluid do these tranis take i put three in
Guest
Posts: n/a
Re: swapped my h23 trani for an h22 trani have a few ?s........ (lshatch1.8)
2 quarts if it was empty!
I am pretty sure - almost positive the VSS are different
no idea about the slave cylinders
what kind of noise?
Are you confident you did everything right?
what kind of noise?
Re: swapped my h23 trani for an h22 trani have a few ?s........ (MadCityLude)
yeah everything was done right only makes a noise kinda like a chatering when the clutch is out.. ( could be the vss .. could be to much fluid ect..) ill get everything fixed tommrow be for i drove ther car and post up thanks
put the vss that came with the trani and it still doesnt work.. no check engine lights but no speedo and no vtec anyone have any ideas also let some of that fluid drain out trani seems to be ok
