Airbag Replacement
Old Sep 16, 2006 | 05:57 AM
whatala's Avatar
Default Airbag Replacement
Hi all,
My car is 1995 Si Prelude and I was in a accident and both airbags deployed. Anyone here replaced airbags before? Any instruction how to do it?
Thanks for your feedback.
Jason
Old Sep 16, 2006 | 10:03 AM
Silver Surfer's Avatar
pain in the ***, because you have to replace all the sensors.....not just swap in new bags
i'd look for a dash swap for the ones with out a passenger air bag.......and maybe a dc2 type r steering wheel without airbag
if you were gonna have to spend money anyway
Old Sep 16, 2006 | 02:38 PM
BlueLude94's Avatar
Default Re: (Silver Surfer)
what sensors? I just replaced the bags hooked 'em up and ran it. the driverside there are 2 6 point star bolt(I recommend buying the right bit that fits) and the pass. has 4 bolts holding it on above the glove-box...
Sorry no pics of the pass. side
Old Sep 16, 2006 | 04:40 PM
Default Re: (BlueLude94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude94 &raquo;</TD></TR><TR><TD CLASS="quote">what sensors? I just replaced the bags hooked 'em up and ran it</TD></TR></TABLE>
good luck in your next accident........im gonna write some direct quotes from one of my manuals
"The system is NOT repairable at home"
"The system must be checked after ANY frontal accident, even if the system did NOT deploy"
"the sensors and control module are behind the dash board"
not to mention these are first generation air bags which are known to have a higher chance of actually harming you in an accident because of the speed of deployment
there is a reason that repair costs are usually around $1500 per bag.......it's a sensitve system that requires special diagnostic tools to check and ensure proper function
Old Sep 17, 2006 | 12:32 AM
jaywoodz's Avatar
go to the junk yard and find one in a prelude, that's what I did, ended up paying about $40 for it (steering wheel included)
Old Sep 17, 2006 | 10:31 AM
"The system must be inspected by a Honda dealer 10 years after the date of manufacture as shown on the certification plate. Note that this build date will be earlier than your actual purchase date."
trust it if you want to though
Old Sep 17, 2006 | 07:26 PM
bburtonsk8r2's Avatar
my lude was pretty much totalled when i got it, i do body work and straitened the frame and replaced ****, both bags were blown, i have replaced both which isnt hard, be careful with the clips though, and u have to replace the module whenever!!!!!! the bags blow. it is under the center console, and ur srs light will not go off unless u replace this
klarsen4
Mar 29, 2008 12:32 PM
cinaibur
Honda Civic (2001 - 2005)
16
Nov 10, 2006 10:41 AM
logicdc
Sep 7, 2006 03:29 PM
jdmspoonitr
Feb 3, 2006 07:11 PM
toooslow
Aug 21, 2003 07:28 PM
