4th gen audio problem. Help.
Old Sep 18, 2006 | 01:12 PM
street_ride14's Avatar
Default 4th gen audio problem. Help.
I ordered from Japan the 4th gen Rear Center Sub unit, came with bracket, 6x9 sub, and OEM amp. I wired everything up (factory existing green harness to amp and the remainding two wires to the +,- of the speaker. Everything works like it should on Radio mode, but I when I switch to play CD, the bass dissapears - nothing coming out of the sub, rest of the speakers work.
I noticed that on the JDM harness that goes to the amp, there are 10 wires. On my USDM harness there are 9 wires. What does the extra wire serve for?
Also I have an aftermarket Sony in-dash receiver.
Just wanted to know if this happens to any of you or are my wiring messed up?
Will try to post some pics later tonight to show exactly what I'm dealing with.
Modified by street_ride14 at 5:41 PM 10/2/2006
Old Sep 18, 2006 | 01:57 PM
darkspector2.0's Avatar
do you have the proper remote wire hooked up?
Old Sep 18, 2006 | 02:09 PM
stylez's Avatar
check your ground
Old Sep 18, 2006 | 06:03 PM
esedulerp5tenin's Avatar
Default Re: (stylez)
where'd you get the 6x9 sub??? i thought they stopped making them awhile.
i'm also interested in doing this
Old Sep 19, 2006 | 08:05 AM
VtecFreePrelude's Avatar
you have your power antenna wire hooked up to your amp turn on. switch them and it'll be fine
Old Sep 19, 2006 | 09:26 AM
mgags7's Avatar
no he is saying the way that amp knows to turn on is when you turn the radio on, the antenna gets power...you need to run the remote wire from your head unit to that same wire on the amp, and just cut it from the other source so the antenna doesnt go up always.....
Old Sep 19, 2006 | 10:32 AM
my9thtry's Avatar
Default Re: (street_ride14)
ok the amp rem goes to your amp so it will stay on when the ignition is on. if you can find the power wire for the amp just tap it into that remote wire on your headunit
xthekidx
Jan 26, 2007 11:49 AM
jclamor87
Mid-Atlantic (Sales)
Jun 14, 2006 08:22 PM
projektvtec
Audio / Security / Video
Sep 8, 2005 07:18 AM
noob with an RS
Dec 29, 2004 09:41 AM
s73
Apr 18, 2002 12:51 PM
