Trunk springs and superchargers?!?!
I figure someone had to make some trunk springs that will fit larger speakers... Know where I can find some?
Now, this I could honestly care less about because I wouldn't be able to afford it for quite some time... JRSC/roots blower on a stock 4th gen h23, I know they make the 97+ kits, but I haven't seen mention of converting to 4th gen, let alone non-vtec. Anyone? is it possible to take the blower for the 97+ and adapt it?
thx
thx
Re: Trunk springs and superchargers?!?! (jamieson)
I heard there is a clearance issue with the firewall but that is with the h22 4th gen..I doubt you would be able to make that work with the h23 because the jsrc intake wouldn't match up with the h23 block.. not sure if they make a charger for the h23/f23 but that's what you would need i think.
Re: Trunk springs and superchargers?!?! (Chuckles99SH)
I think the supercharger utilizes the stock bottom half of the manifold (the top part is the same) so as far as that goes the h23 bottom part would work, but the shock tower is in the way of where the belt needs to go. Even with that goofy pulley system they (jackson) have rigged up, I think it will still hit.
