buy another longblock or rebuild h23a1
planning to go turbo with my h23a1...it has a lot of miles right now and has a oil leak...now should i rebuild the motor that i have now or pick up another cheap longblock...
Re: buy another longblock or rebuild h23a1 (94_SI_lude)
My suggestion is either a stock F22 Accord engine with low boost, or take the H23 head off your current engine and mate it to an F22 or F23 bottomend, upgrade the rings, and boost it some more.
Either way, use an F series bottomend.
Guest
Posts: n/a
Re: buy another longblock or rebuild h23a1 (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">My suggestion is either a stock F22 Accord engine with low boost, or take the H23 head off your current engine and mate it to an F22 or F23 bottomend, upgrade the rings, and boost it some more.
Either way, use an F series bottomend.</TD></TR></TABLE>
Thats what I am doing - option 1 with an H23 head.
Re: buy another longblock or rebuild h23a1 (MadCityLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">Neither
Buy an F22 or F23 bottom end and use your head
Or buy an F22b JDM DOHC longblock off ebay for $500.
Sell yours.</TD></TR></TABLE>
if i do pick up a f22b jdm dohc longblock what tranny do i use and what ecu??
would all my h23a1 parts or most of them fit on the f22b?? or would i have to buy some other parts?? please list some parts i would need so i can go get them soon...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">Pretty much all the parts your would need can come off your H23a
Just buy things like water pump, seals, gaskets, fluids, clutch/flywheel, belts, plugs, wires, filters (gas/air), etc.etc...</TD></TR></TABLE>
what parts are needed from a f22b??
Guest
Posts: n/a
What? Use as many F22b parts as possible. You just may need to use your sensors and stuff. I am not real sure.
I am pretty sure all the parts you buy will be for the H23 though. They are very similar.
There is a few threads here on HT about that engine if you search you can find some good info.
