quick question
Old Jan 28, 2008 | 03:28 PM
2.3Preludevtec's Avatar
Default quick question
I just turned 30 and finally saved up the money to finish the work on my 01 prelude. After long days spent in auto-tech school and countless hours working to save up enough money im just about done with her. I do have a few questions
Mods:
Ported/Polished all intake and exhaust ports
5 cut Valve Job
forged type s pistons
forged connecting rods
h23 crank(grinded evenly to reduce weight) faster acceleration
crower stage 2 cams with valves/valvetrain/sprockets
all light weight forged alluminum bolts
all light weight pulleys AEM and UR
Greddy evo 2 exhaust with custom test pipe
Hitech header from john
aem v2 intake with k/n airfilter and custom velocity stack
msd ignition
msd wires
ngk plugs
problem number 1....Im running a stock intake mani and stock TB.....any suggestions for upgrading or has anyone ported/polished this unit?
Problem number 2....The car is wayyy to heavy and I really want to keeep the interior nice i mean no taking out carpet...i havent touched the interior completley stock...Ive lightened the motor/exhaust....any ideas i have only 500 for lightweight seats i want to get what company sells insanly lightweight seats?
Old Jan 28, 2008 | 03:47 PM
Default Re: quick question (2.3Preludevtec)
please..anyone ?? i want to get this thing prepped and ready for spring....also right now im running a short throw shifter kit which i do like...however im looking for a lightweight flywheel...i have an exedy clutch...if anyone has a flywheel for sale let me know...im forced to tune my beast on my buddies wideband with this apexi vtec controller for now because moneys tight...in future i want to upgrade to a standalone and possibly obd 1....anyone have any reccomendations?
Modified by 2.3Preludevtec at 5:01 PM 1/28/2008
Old Jan 28, 2008 | 03:53 PM
slamdlude's Avatar
Hondata seems to be the popular thing around here. I'm going with aem, but I'm doing a little more than you are.
Old Jan 28, 2008 | 04:02 PM
Default Re: quick question (slamdlude)
your going with aem because your throwing a turbo on?? ....would my setup benefit more from aem? I veered from going turbo because ive been rebuilding engines for a long time and really wanted to do it to my own...i was actually looking at jrsc but not sure if its compatable with the type s pistons?
Modified by 2.3Preludevtec at 5:13 PM 1/28/2008
Old Jan 28, 2008 | 04:06 PM
twiztid00002's Avatar
your problem number 1 --- go to roskoracing.com im pretty sure he port/polishes his intake manifold. he sells the euroR manifolds for 500 but he customizes them to fit h22's. just read the website and the euroR is like the skunk2s if not better.
Old Jan 28, 2008 | 04:12 PM
Default Re: quick question (twiztid00002)
thanks man i've actually been porting and polishing for the past yearish so i wasnt gonna spend the money to do it but i think ill give rosko a call for some ideas....i was looking at a jrsc but im not sure that would be to safe with my slightly high compression pistons?
Old Jan 28, 2008 | 04:33 PM
well if you can p/p then buy his 300 dollar one and change all the valves n crap he tells u how to do it on the site
Old Jan 28, 2008 | 05:31 PM
skunk 2 makes many different size from 60-70mm...which is best for my setup? im thinking 70mm....also DOES ANYONE HAVE LIGHT WEIGHT SEATS FOR SALE?
Modified by 2.3Preludevtec at 6:56 PM 1/28/2008
Old Jan 28, 2008 | 05:36 PM
well im not an expert but i would guess that the bigger the better (if it fits right) bigger= more airflow=faster
Old Jan 28, 2008 | 08:15 PM
Mikato Soul's Avatar
If you want to drop weight and keep your interior then get carbon fiber/fiber glass panels, fendors, hood, etc. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.3Preludevtec &raquo;</TD></TR><TR><TD CLASS="quote">skunk 2 makes many different size from 60-70mm...which is best for my setup? im thinking 70mm....also DOES ANYONE HAVE LIGHT WEIGHT SEATS FOR SALE?
[QUOTE=twiztid00002]well im not an expert but i would guess that the bigger the better (if it fits right) bigger= more airflow=faster </TD></TR></TABLE>
No always, if you go to big with a NA engine you will loose intake air velocity and loose HP.
Old Jan 28, 2008 | 09:25 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.3Preludevtec &raquo;</TD></TR><TR><TD CLASS="quote">please..anyone ?? </TD></TR></TABLE>
OMG you waited 20 minutes, bahaha.
MemoryFab makes excellent seats, but you may not find them for $500.
I would loose the MSD ignition, I have personally had 2 boxes randomly die out and leave me stranded...they don't do anything anyway. NGK plugs and wires is the way to go.
70mm is a good TB size and have some patience!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid00002 &raquo;</TD></TR><TR><TD CLASS="quote">well im not an expert but i would guess that the bigger the better (if it fits right) bigger= more airflow=faster </TD></TR></TABLE>
Uhh...nope. Bigger airflow path means more air (if the engine even needs it) at higher rpms, but lower velocity at low rpms which hurts power. Hence the stock 2-stage intake manifold.
Old Jan 29, 2008 | 06:14 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid00002 &raquo;</TD></TR><TR><TD CLASS="quote">well if you can p/p then buy his 300 dollar one and change all the valves n crap he tells u how to do it on the site</TD></TR></TABLE>
there arent any valves to change
no.
to the op:
type S pistons are not forged, they are cast.
go with a 3" exhaust
there are better cams for the time and money spent
Old Jan 29, 2008 | 06:54 AM
Acidcrakker's Avatar
Default Re: quick question (98vtec)
Check out Maxxbore.com
Port and Polished TB'S
Its on my next Mod list.
Old Jan 29, 2008 | 09:26 AM
Infinity_Racer's Avatar
Default Re: quick question (Acidcrakker)
the buddy club seats are fairly light...i had them in my s2k and they are pretty comfy and light weight...and the price of them isnt too bad...theyre about 320 at evasivemotorsports.com
hondahead814
Honda Civic (2006 - 2015)
Jan 2, 2009 11:48 PM
CCD-R
59
Dec 14, 2006 10:28 AM
bigz187
Mar 19, 2006 06:28 PM
JDMVTEC
Jan 8, 2004 10:59 AM
