clutch?
Old Feb 2, 2008 | 12:31 PM
l.u.d.e.51's Avatar
Default clutch?
i have a 1994 prelude si and i was driving and i noticed when i accelerated it sounded like the clutch was slipping after i shifted then it wouldnt even go in a gear any ideas?
Old Feb 2, 2008 | 11:29 PM
dagle's Avatar
Default Re: clutch? (l.u.d.e.51)
check your master / slave cylinder.. could be leaking.. simple/cheap stuff first
Old Feb 3, 2008 | 09:26 AM
l.u.d.e.51's Avatar
Default Re: clutch? (dagle)
i checked the slave cylinder it still moves so im thinking it could just be the clutch because it was slipping when i would downshift
Old Feb 3, 2008 | 02:35 PM
8_6 luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle &raquo;</TD></TR><TR><TD CLASS="quote">check your master / slave cylinder.. could be leaking.. simple/cheap stuff first</TD></TR></TABLE> If that were the problem how would you go about fixing it ? Whats the replacement part called ? Im using a hose clamp at the moment . Sorry for the imposition but im dealing with a similar slave cylinder issue.
Modified by 8_6 luder at 1:16 AM 2/4/2008
Old Feb 4, 2008 | 01:27 PM
l.u.d.e.51's Avatar
Default Re: clutch? (8_6 luder)
my local mechanic looked at it and he said it could be the pressure plate shouldnt be to hard of a fix
Old Feb 4, 2008 | 01:42 PM
NightHawkLude99's Avatar
I would replace the whole clutch not just the pressure plate.
Jason
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
kaz8teen
Dec 1, 2007 09:30 AM
Lasty K
21
Jun 8, 2007 05:05 PM
TheAccordGuy
Nov 9, 2006 04:41 PM
Sivicfied
15
May 3, 2005 12:59 PM
