How do you remove the rear seat?
How do you remove the rear seat on a 95 prelude Vtec
Ok, did a search here and on web and cant figure out how to pull the rear seat. I am replacing a cd changer and cant get the wire out, it is going under the rear seat. It is a 95 Prelude Vtec
Re: How do you remove the rear seat on a 95 prelude Vtec (caliskier)
The lower sections of the seat are pretty easy to take out.
There are two clips under the front of each seat. if you find the clips you pull out on them. sometimes they are a little hard to pull out. if you push down on the seat then pull out the clip the seats will pop right out.
Re: How do you remove the rear seat on a 95 prelude Vtec (kulrevon)
Thanks so much, I just figured that out, how frustrating it was. I messed with that thing for 30 min. Was afraid of those clips until I got the plyers to them, poped right out. Thanks
Location: Forced to leave Austin, TX for, Oklahoma, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon »</TD></TR><TR><TD CLASS="quote">The lower sections of the seat are pretty easy to take out.
There are two clips under the front of each seat. if you find the clips you pull out on them. sometimes they are a little hard to pull out. if you push down on the seat then pull out the clip the seats will pop right out. </TD></TR></TABLE>
What about the top part of the seats?
Re: How do you remove the rear seat on a 95 prelude Vtec ((null).exe)
there are 10mm bolts that you need to remove....theres i think 2 on the driver side, and 2 on the passanger side...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude »</TD></TR><TR><TD CLASS="quote">there are 10mm bolts that you need to remove....theres i think 2 on the driver side, and 2 on the passanger side...</TD></TR></TABLE>
yup, then they slide straight up+out
Re: How do you remove the rear seat on a 95 prelude Vtec (95greenlude)
woot! there's now a giant hole from the cabin back into the trunk!
behind the back seats there's some cross bracing...anyone know if it's needed to prevent body flex? i'm sure it doesn't weigh much, but with a 2800 lb car stock, any little bit helps.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (null).exe »</TD></TR><TR><TD CLASS="quote">woot! there's now a giant hole from the cabin back into the trunk!
behind the back seats there's some cross bracing...anyone know if it's needed to prevent body flex? i'm sure it doesn't weigh much, but with a 2800 lb car stock, any little bit helps.</TD></TR></TABLE>
I don't think it does much considering it's thin and bolted in, but if you don't have to remove it don't. The rear shelf is welded in and it probably would have more negative effect (than the brace) if it was taken out.
Re: How do you remove the rear seat on a 95 prelude Vtec (Hawkze_2.3)
ok i guess i'm leaving it in then :D
now, who wants some OEM blue rear seats with all the hardware? *grin*
i know, i know...off to the F/S thread for me...
