help with crazy idle....
Old Mar 2, 2004 | 07:25 PM
Bigjussin's Avatar
Default help with crazy idle....
hey guys...i got my swap in and running.....FINALLY.....but the idle jumps from 500-2500....i checked for all possible vacuum leaks, and am going to replace the IAC tomorrow morning to see if it helps...other than that, can anyone shed some light on the situation?
TIA
Old Mar 2, 2004 | 09:14 PM
ludeR917's Avatar
Default Re: help with crazy idle.... (Bigjussin)
check your idel screw near the tb, make sure its not all the way out (like mine)
check for vacuum leak, AGAIN
dont replace the IAC, try taking it out and clean it
check the fast idle make sure its not loose
it this dont fix the problem, your SOL
Old Mar 2, 2004 | 09:15 PM
ludeR917's Avatar
Default Re: help with crazy idle.... (ludeR917)
forgot to ask, when does this happen? when you start up the car or when its warmed up?
Old Mar 3, 2004 | 03:02 AM
TXcivic96's Avatar
If it's a JDM swap on mine it was the IAC valve at the bottem of the throtle body mine did the same thing 700-3000rpm gets really annoying but the vlave off a GSR fixed it right up no idles at 690-725rpm all the time.
Old Mar 3, 2004 | 08:30 AM
Bigjussin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 &raquo;</TD></TR><TR><TD CLASS="quote">forgot to ask, when does this happen? when you start up the car or when its warmed up?</TD></TR></TABLE>
almost always...it will idle ok at first cold start for like 30 seconds...then it will kick into the loping....it kinda sounds like i have some brutal cam in it...but thats not what im going for
THANKS TO EVERYONE FOR THEIR HELP!
Old Mar 3, 2004 | 08:32 AM
Bigjussin's Avatar
Default Re: help with crazy idle.... (jdmboostedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboostedlude &raquo;</TD></TR><TR><TD CLASS="quote">If it's a JDM swap on mine it was the IAC valve at the bottem of the throtle body mine did the same thing 700-3000rpm gets really annoying but the vlave off a GSR fixed it right up no idles at 690-725rpm all the time.</TD></TR></TABLE>
wouldnt that be the fast idle thermo valve, cus my engine is the jdm motor, and the IAC is on the front of the Intake Mani, behind the rail and injectors
thanks though...im gonna check it as soon as i get home from class...peace
Old Mar 3, 2004 | 08:48 AM
DW's Avatar
DW
also if your coolant is low and it has an air pocket in the iac then it will do the same thing. top that off before you go replacing it
David
Old Mar 3, 2004 | 09:32 AM
lude_si_95's Avatar
Default Re: help with crazy idle.... (DW)
SEARCH!...there are probably 25 posts about this
Old Mar 3, 2004 | 05:41 PM
Puki
Guest
Posts: n/a
Default Re: help with crazy idle.... (lude_si_95)
I have the same problem, it started out only when the car was cold. Now it revs all day. It ranges from 1k to 3k.
Im assuming its a vaccum leak. I have to fix it soon, its not nice in commute traffic, When I push in the clutch to ride 1st and second gear the car will accelerate then just stop and the car jolts.
Old Mar 3, 2004 | 07:06 PM
Bigjussin's Avatar
Default Re: help with crazy idle.... (Puki)
FIXED...it was the Fast Idle Thermo Valve...took it off, and it was backed all the way out...so i screwed it in a little bit...and it worked fine....not to mention my idle screw was all the way out...so it would idle at like 3k....but thats all fixed.....
thanks to all who put in their two pennies
TegraD
Aug 20, 2008 04:49 PM
IntegraType-R
11
Jan 20, 2008 11:23 PM
Midori Green
Jan 3, 2007 03:13 PM
eg6nes
Feb 21, 2005 03:57 PM
4gen
Jan 11, 2004 05:28 PM
