Fuel Filter problems...
Old Mar 7, 2004 | 02:33 PM
96LudeSR's Avatar
Default Fuel Filter problems...
Hey guys.
I was trying to change my fuel filter this weekend and I am having a problem. The problem is that the bolt that holds the gas line coming from the gas tank just won't turn. I purchased a crow foot and attached it to my wratchet but it just won't break free. I even tried with a flared nut wrench but no luck. I tried lubricating it with WD40 but that didn't help either. I cannot heat it because it's on the gas line and it's not safe. I purchased a drill bit that drills into steel. Is there anything else I should try before I go ahead and drill into it?
Any help would be greatly appreciated.
Thanks.
Old Mar 8, 2004 | 05:55 AM
Max_lude's Avatar
Default Re: Fuel Filter problems... (96LudeSR)
i got the same problem and dont know what to do?
Old Mar 8, 2004 | 08:30 AM
boxer's Avatar
This is just a thought,but could it be the filter has left hand threads?
If so, you would be tightning the filter instead of loosening it.
Other than that, I would continue to spray some liquid wrench on it and just let it soak.
Good luck.
cholder919
Sep 11, 2011 05:03 PM
casper.hughes
Oct 6, 2008 04:34 PM
sleepercivic88
Aug 23, 2008 12:14 PM
Uncle Ben's
Apr 19, 2006 03:56 PM
SiMateoAko
11
Feb 23, 2006 08:23 AM
