Pin out
Old Mar 2, 2004 | 01:01 PM
darylfiend11's Avatar
Default Pin out
I know this has been up before and i tried to search. But what is the pin out for a 1992 prelude 2.3L non vtec? Please help.
Old Mar 2, 2004 | 01:03 PM
PrecisionH23a's Avatar
Default Re: Pin out (darylfiend11)
The pin out for the ecu? Which pins are you looking for exactly? If you are installing the afc, check out http://www.apexi-usa.com for pdf documentation.
Old Mar 2, 2004 | 01:04 PM
yes its for the ecu. Yes its for the afc sorry forgot to mention i guess it would've helped alot.
Old Mar 2, 2004 | 01:10 PM
http://www.apexi-usa.com/documentation.asp
the only diagrams i saw were for the h22a
Old Mar 3, 2004 | 12:37 PM
i called apex and the don't even know. There has got to be one of you that has had this problem before. Please Help.
Old Mar 3, 2004 | 12:50 PM
Soda Popinski's Avatar
I'd thinkl it be the same as the h22 except without the vtec stuff.
Old Mar 3, 2004 | 01:13 PM
Default Re: Pin out (BeeBeeOne)
Yep. I remember when doing the s-afc a few years ago I used the h22 diagram for only the needed wires shown in the instruction manual.
Old Mar 3, 2004 | 01:17 PM
v4lu3s's Avatar
RTFM
all obd1 is the same
so you could use it for the h22a, the f22 engines, the d16z6, b18c1 etc...
Old Mar 3, 2004 | 01:18 PM
93ludeSi's Avatar
Default Re: Pin out (PrecisionH23a)
http://www.92lude.com has a pin out for the p14 and p13. go to the the "repair manual link" and the scroll down to j- pin voltage
sins
Jan 8, 2010 10:11 PM
skylude23
Jan 18, 2007 06:54 AM
TN90accord
Jun 24, 2006 12:19 PM
GladmanPerformance
Apr 3, 2004 04:36 PM
