Temperature Question
Old Mar 4, 2004 | 09:14 PM
92LudeSI's Avatar
Default Temperature Question
My temp gauge has been goofy lately. When my car is just sitting warming up say it wil read normal temp when its supposed to. Then once i start driving it it drops down to half temp. The one night even after beating on it for a good 15 min it was still only half temp. What might be the problem the thermostat?? Also would i benefit from replacing it or could i get away without. Thanks
Old Mar 4, 2004 | 09:38 PM
Monkey Fing a Coconut's Avatar
Default Re: Temperature Question (92LudeSI)
i'm kinda confused, u said u would let it warm up to normal temp and then when you start driving it would DROP to half temp, isnt normal temp a little under half, and shouldnt it stay there even with a beating, 15 min of vtec and mine stays just below half
Old Mar 5, 2004 | 12:58 AM
@ries's Avatar
Default Re: Temperature Question (twistedbydezign)
I agree. Isn't normal operating temp. at half way on the temp. gauge?
Old Mar 5, 2004 | 02:49 AM
superturboprelude's Avatar
i have a koyo radiator and when i race on the freeway or hit vtec for a while my temp gauge drop one bar from the half line and when i stop and drive normal it goes back to the half way mark is this normal or is there something wrong with my thermostat?
Old Mar 5, 2004 | 06:25 AM
JDMSloLude's Avatar
Its probably that your thermostat is stuck open. When you thermostat is stuck open your temp gauge will drop because of the air temp. Swap the thermostat but I advise buying it from Honda. This recently happened to me and and I bought a thermo from Advance that was too small(they stock the wrong part). $30 part...maybe 60 min labor.
Old Mar 5, 2004 | 07:07 AM
92LudeSI's Avatar
normal temp is half way or 2 bars what i meant was that say in the winter or in the mornings (its still a bit chilly) I start my car when i get in it will be 2 bars or half way on the gauge or normal operating temp. But when i drive it it drops to one bar or halfway between normal and 0 is what i had meant. Where is the thermostat at? If i just pop one of the radiator hoses off its right there correct by the IM manifold.
Old Mar 6, 2004 | 03:10 PM
JDMSloLude's Avatar
Default Re: (92LudeSI)
yea dude its your thermostat. Its on the left side of the engine if you are facing it from the front. Its pretty simple, drain the radiator, pop the thermostat out. The exact same thing happened to me a lil while ago. ITs a pain in the ***. But your thermostat is stuck open and when you pull it out you will see what i mean.
Old Mar 6, 2004 | 09:57 PM
92LudeSI's Avatar
which hose is it located at. The front or the back? and by fixing this did you notice anything different other than the temp. staying constant? I guess im wondering if it really needs to be fixed at the moment or can it wait. As is seems it is hurting nothing but you never know.
Modified by 92LudeSI at 1:50 AM 3/7/2004
Old Mar 7, 2004 | 08:57 AM
JDMSloLude's Avatar
Its in the back on the water neck. It is nothing of emergency to fix, i ran mine that way for about a month. I just got sick of having no heat. Basically your thermo is stuck open so your coolant never is on a closed loop to get hot. Check out a diagram online and you should have no problem. Good luck, and remember to get the part from honda
Old Mar 7, 2004 | 01:14 PM
92LudeSI's Avatar
This is the thing thou I do have heat. Ive drove it like this all winter where i would have heat but it would jsut never warm up to normal opperating temp. Can it still be stuck open and have heat?
Old Mar 7, 2004 | 10:14 PM
Variable J's Avatar
Well then it seems like you dont need to fix it right away. Leaving the thermostat stuck open shouldnt cause any major problems.
Old Mar 7, 2004 | 10:15 PM
Variable J's Avatar
Default Re: (Variable J)
Unless you notice you start to overheat you shouldnt have any problems.
Old Mar 8, 2004 | 07:34 PM
92LudeSI's Avatar
Went to honda today and got a new thermostat ($15) Works like a charm its amazing how fast the car heats up now and I actually have Hot heat haha. Thanks for all of your help!
Old Mar 9, 2004 | 07:02 PM
ludeboy555's Avatar
get a mugen thermostat it really helped me a lot
agb22
17
Mar 7, 2017 07:11 AM
lilo_goki
Mar 27, 2011 09:38 AM
PhantomSTi
Jun 20, 2004 12:31 PM
jman
Oct 12, 2002 08:20 PM
