what will my comression be?
Old Mar 4, 2004 | 10:53 AM
ensracer's Avatar
Default what will my comression be?
im going h23 vtec and all i have to do is put the head on which im doing as im speaking im running 2001 h22 pistons and i milled the head 40 over....i just wondering because i was told that compression ratio works just a tad bit different when doing h23 vtec.....thanks
Old Mar 4, 2004 | 11:22 AM
PirateMcFred's Avatar
Default Re: what will my comression be? (eduardo)
I think that you will be running about 11.5:1.
info needed to calculate...
H22 head cc 53.8cc
H23 bore 87mm
H23 stoke 95mm
OEM head gasket .027"
effective OEM Gasket thickness after.040" mill = -.013
H22 piston cc ~2cc
Oh BTW, your cam timing will be retarded about 1.1° cuz the .040" mill.
So you might look into some adjustable cam gears.
the Pirate
Old Mar 4, 2004 | 11:44 AM
ensracer's Avatar
the 11 5 1 sounds just awsome but the retarded timing just sucks. i fugured that i would set the timing on the distributor to like 18...what do you think
Old Mar 4, 2004 | 11:56 AM
Default Re: (eduardo)
cam timing is completely different than ignition timing
bad cam timing gets you piston to valve contact like when your timing belt snaps
bad ignition timing gets to reduced power/effiency(when retarded) and knocking (when advanced)
Old Mar 4, 2004 | 12:15 PM
ensracer's Avatar
wow i see... so for sure cam gears are nesessary?
what should i set my distributor at
Old Mar 4, 2004 | 02:19 PM
One degree is really not that much but when you go all motor and you are trying to squeeze all of the power out of you engine then Adj. cam gears are a good idea to play with cam settings. Otherwise $200 can be spent elsewhere like learning to drive.
Set your ignition timing to 15°, I believe that is what the mark on the flywheel is. Otherwise it is something that you need to tune on the dyno for the most power.
the Pirate
Jmar9289
Jan 25, 2011 12:56 PM
h22ej8
Mar 18, 2009 04:21 PM
jdmh22luda
Oct 14, 2005 11:32 AM
mstewar
Jul 11, 2005 11:24 AM
donnjuan2point2
Mar 11, 2004 01:59 PM
