checking codes
Old Mar 2, 2004 | 05:44 AM
TylerB's Avatar
Default checking codes
my cel is coming on at certain times and im unaware of how to check it on a prelude, can some one explain (searched)
Old Mar 2, 2004 | 08:08 AM
Filthy Focker!'s Avatar
Default Re: checking codes (H22 VTEC)
On the passenger side of your car, under the dash beneath the glove box, you will find a green cover above the kickpanel that houses a blue connector that has two wires.
That you need to do is turn the ignition off, and using the piece of wire or paperclip, jump the blue connector so that you connect the two wires together. Basically stick one end of the paperclip or peice of wire into one prong on the connector and stick the other end of the paperclip or wire into the other prong.
Once you have done this, turn the key to the IGN position and watch your CEL light. It will illuminate in a series of flashes.
You will notice that there will be LONG flashes and SHORT flashes. All of the ECU trouble codes are two-digits. LONG flashes determine the TENS digit by the number of times it flashes, and SHORT flashes determine the ONES digit by the number of times it flashes.
fs
Old Mar 2, 2004 | 08:13 AM
SuzukaBlueAP2's Avatar
Default Re: checking codes (filthy_shovel)
Look for this...
and do this...
**EDIT** That is for OBDII
Old Mar 2, 2004 | 08:33 AM
99spanishGT
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">On the passenger side of your car, under the dash beneath the glove box, you will find a green cover above the kickpanel that houses a blue connector that has two wires.
fs</TD></TR></TABLE> is this on a 92-96 prelude because 4bidden told me it was by the gas petal but i only had a blue connector with 3 holes, so where would mine be??
Old Mar 2, 2004 | 06:40 PM
99spanishGT
Guest
Posts: n/a
Default Re: checking codes (spanishlude)
bump !!!
Old Mar 2, 2004 | 08:18 PM
9deuce9rr's Avatar
i'm looking for the same plug on a 92 lude. i figured since his is a 94 it'd be in the same place but i'm not findin it. bump
Old Mar 2, 2004 | 08:19 PM
4bidden's Avatar
Default Re: checking codes (WhiteLude)
Reach behind the center console down by the gas pedal. It'll either be danglin there or it will be plugged into a dead connector.
Old Mar 2, 2004 | 08:20 PM
99spanishGT
Guest
Posts: n/a
look down by gas petal
Rory Breaker
Apr 7, 2024 05:45 PM
Ricky Equihua
Nov 2, 2013 09:00 AM
yoshio006
May 22, 2005 06:49 PM
Evilducky
Aug 15, 2004 11:26 PM
93EH6
Jan 30, 2003 09:11 PM
