Idle Problem?
Old Mar 6, 2004 | 10:01 AM
aznplyboi15's Avatar
Default Idle Problem?
I Had my JDM H22A motor rebuilt and it idle's really rough? What are some of the main cause?
Old Mar 7, 2004 | 06:50 AM
luda94's Avatar
Default Re: Idle Problem? (aznplyboi15)
does the idle rise and fall continuously or does it just idle rough? if it is rising then falling your O2 sensor is probably bad but just replacing it wont fix it. (exhaust leaks will cause new one to go bad) if it is just idling rough then check for vacuum leaks or EGR system failure. does it run ok off idle?
Old Mar 7, 2004 | 06:52 AM
MattCook1234's Avatar
Default Re: Idle Problem? (luda94)
dirty injectors
dead fuel pump
sticky thermostat
Aguem2
Aug 10, 2013 10:05 AM
GreenMachineRex
Sep 22, 2005 03:12 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
Magick211
Jun 21, 2002 05:18 AM
