oil
Old Mar 8, 2004 | 10:17 AM
nver2's Avatar
Default oil
I dont have the oem manual what oil weight would be best for my 88 lude S. I used 10w 30 last time does that sound right?
Old Mar 8, 2004 | 10:30 AM
jdmlude_dude's Avatar
Default Re: oil (nver2)
5w30
Old Mar 8, 2004 | 01:05 PM
@ries's Avatar
It depends on the mileage of the car... generally the higher the mileage the thicker the oil. Althought they do have special oil formulated for car's with higher mileage motors.
Old Mar 8, 2004 | 02:05 PM
mattmw88's Avatar
Default Re: oil (emoBB1)
also depends on your climate... 5-30 is a thinner oil that is easier on your car incold starts... 10-30 is a thicker oil that should be used if you have an oil leak, as it will slow the leak down.
Most High milage oils do work. They have addatives that penatrate the gaskets and try to rejuvinate the life in them(make them softer and bigger), but obviously these don't always work. The chance of them working gets better the more you use it too.
Hope this helps...
Old Mar 8, 2004 | 03:16 PM
nver2's Avatar
Default Re: oil (mattmw88)
it has 185,000 miles on it and i live in Florida
FitsMe
Honda Fit
Apr 16, 2012 05:05 AM
EG-SIXV-TEC
27
May 3, 2010 09:27 AM
Wish2345
26
Mar 23, 2010 01:47 AM
Inextricabledrvr
May 3, 2008 09:42 AM
vinuneuro
Mar 15, 2005 04:41 PM
