5th gen getting lean error code
Old Mar 7, 2004 | 11:24 AM
superprelude87's Avatar
Default 5th gen getting lean error code
i'm not sure why i'm getting a lean error code.
When i start the car my gauge says its rich then as i drive for the 1st minute it slowly makes its way down to lean and the off the gauge. Before i gutted the cat it would bounce back and forth at idol like it should now it doesn't
I did gut my cat so i think that the o2 is giving the ECU rich readings so the engine is ECU it lean.
What should i do get a new cat, o2 simulator
HELP
Old Mar 7, 2004 | 11:26 AM
Default Re: 5th gen getting lean error code (superprelude87)
REVISED the end of the 1st is confusing
I did gut my cat so i think that the o2 is giving the ECU rich readings so the ECU is making the engine lean
HELP
Old Mar 7, 2004 | 11:53 AM
Variable J's Avatar
I'm sorry I dont really have an answer but what happens when you wanna get a dyno done and your going to use a test pipe instead of the cat. I havent done it yet but I was going to in a month or so. Im sure someone who has done this would have some info.
fleshwounded
Jul 22, 2011 06:10 PM
Crazyxc2448
Mar 25, 2010 03:56 PM
Two_K Si
Oct 13, 2004 08:32 PM
