Compression and leak down tests
Old Sep 14, 2004 | 07:59 PM
FalconMan's Avatar
Default Compression and leak down tests
Compression and leak down tests.......can i do them myself...or they to complicated?
Old Sep 14, 2004 | 08:44 PM
Shakes's Avatar
space cadet
Default Re: Compression and leak down tests (FalconMan)
i did my comp test in about 15 minutes. i havent done a leakdown and dont know what all is entailed.
1 - get compression tester from autozone for about $20
2 - remove all spark plugs
3 - lightly coat the threads of the comp tester with anti sieze
4 - screw comp tester into #1 cyl
5 - crank engine over 5 times
6 - take reading.
7 - repeat 3 times each cylinder then redo #1 (or which ever you first )
Old Sep 14, 2004 | 08:55 PM
SKDRCR's Avatar
Default Re: Compression and leak down tests (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">i did my comp test in about 15 minutes. i havent done a leakdown and dont know what all is entailed.
6 - take reading.
7 - repeat 3 times each cylinder then redo #1 (or which ever you first )</TD></TR></TABLE>
Correct me if i'm wrong, but shouldn't you also push
the pedal to the metal " ", while cranking it as well?
Also i think if you pull the fuel pump relay,
it won't dump fuel in the cylinders while your testing it.
Old Sep 14, 2004 | 09:30 PM
Shakes's Avatar
space cadet
Default Re: Compression and leak down tests (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
if you pull the fuel pump relay why would you put the pedal to the metal?
i did neither. i just cranked it 5 times and read the gauge.
Old Sep 14, 2004 | 09:37 PM
SKDRCR's Avatar
i did neither. i just cranked it 5 times and read the gauge. </TD></TR></TABLE>
When I did mine a while back, i did it the same way as you.
But I know some people do it the other way ( at wot with the fuse pulled )
I can see what the helms says tomorrow on it
Old Sep 14, 2004 | 09:49 PM
Shakes's Avatar
space cadet
I can see what the helms says tomorrow on it </TD></TR></TABLE>
i didnt even think to consult the HELM. i just called BEN.
BTW, lovin that speed racer avatar!
Old Sep 15, 2004 | 02:56 AM
Behan's Avatar
You should have the throttle wide open when doing the compression test., Other then that follow Doug's instructions.
A leakdown tester is like 70.00 - 100.00, IIRC. Basically you need to put the piston at TDC and you fill the cyl with compressed air. Then you monitor pressure loss via the tester
EdwinCheng
May 8, 2014 02:26 PM
jorge59la
Mar 16, 2007 10:34 PM
johnny_dc2
Apr 27, 2006 05:10 PM
zracer240
Apr 24, 2005 08:35 AM
wm5holla
Mar 23, 2003 03:39 PM
