taillights
Old Sep 9, 2004 | 10:29 AM
esca's Avatar
Default taillights
is the turn signal in the taillights an amber bulb.. or is it clear.. i was thinking about doing a tailight conversion.. and dotn wanna get pulled over for white turn signals.. thanks
Old Sep 9, 2004 | 10:45 AM
blk97lude's Avatar
Default Re: taillights (esca)
our tail lights has a orange/amber lense.. so, if u want to take out the lense you would need a soldering iron and break the lense into pieces to take it out..
Old Sep 9, 2004 | 10:52 AM
esca's Avatar
Default Re: taillights (blk97lude)
i ment the blub.. i know the lens is amber.. you gotta put it in the oven to melt the glue off to take off the lens from the housing.. but.. i was wondering if the bulb was amber or clear?
Old Sep 9, 2004 | 11:11 AM
Mr.Dew's Avatar
Yep, it's Eric.
4th gen? it's clear. when the light goes through the amber lens it comes out orange.
Old Sep 9, 2004 | 11:42 AM
TxTuner
Guest
Posts: n/a
Default Re: taillights (oNeMoBB1)
Best way to remove the amber lense is to bake the light at 250 degrees for about 5 minutes. Take it out and pry the lense off. The baking simply loosens the "sticky ****" that holds the lense on. Once you've pulled the amber lense simply reverse the order to put the outer lense back on. VOILA!!! But yes, the bulb is clear
sireg6
10
Jan 21, 2008 08:56 PM
atlj007
Lighting
15
Dec 7, 2007 12:39 PM
xmx250
Honda Civic (2006 - 2015)
Apr 9, 2007 08:38 AM
msinsky14
Jul 27, 2006 06:12 PM
itr_dc2
Aug 3, 2004 04:13 PM
