Installing Camber Kits
Old Sep 14, 2004 | 06:48 AM
Shakes's Avatar
space cadet
Default Installing Camber Kits
So i "should" be doing the suspension tomorrow. i will use the NTPOG link as referance but nowhere have i seen it say anything about installing camber kits.
I have an Ingalls Ball Joint camber kit for the front and Ingalls Anchor Bolts for the back.
For those of you that have done this please post pics, or a general idea of where they go. I'm the suxorz at suspension
Old Sep 14, 2004 | 01:46 PM
Shakes's Avatar
space cadet
Default Re: Installing Camber Kits (Shakes)
oh come on. nobody lowered their lude?
Old Sep 14, 2004 | 01:59 PM
bad-monkey's Avatar
the rear anchor bolts will be easy, as in you can do it yourself.
i don't have pics, but i'll try to be detailed.
if you look at your rear upper control arms, you'll see that it mounts to the chassis by using 2 bolts that attach near the shock towers. If you go into the trunk, and remove the lining, you'll see where these bolts attach with nuts. Take a 17mm socket, and get the bolt that is closer to you. Now, get into the car, and put the rear seat down. You will see 2 rubber circle things, that are covering up the access holes in the plastic for the other 2 bolts. Take your 17mm and get those out. (actually, do it 1 side at a time. drivers then passengers). At this point, you should be able to drop the control arm out (while it's still connected to the ball joint/castle nut) and you should have enough play to swing it out and around. You'll see that there's a long bolt where the control arm connects to the OE anchors. Take them out, replace with camber adjusting anchor bolts, and put it all back together.
for the fronts, you're going to have to find a machine shop, or have access to a press, and press the ball joints out, and press the new camber kit in. separate front ball joints, take the uca's out, and take em to a shop with the camber kit, and they should know what to do.
Old Sep 14, 2004 | 02:12 PM
eLUDEnu
Guest
Posts: n/a
Default Re: Installing Camber Kits (bad-monkey)
shakes Im in the same boat as you! I bought a kit a few months ago from landspeed racing and It came with no instructions and like 100 parts. It is suppose to be ingalls so if you get it down will you do a write up?
Old Sep 14, 2004 | 02:37 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">for the fronts, you're going to have to find a machine shop, or have access to a press, and press the ball joints out, and press the new camber kit in. separate front ball joints, take the uca's out, and take em to a shop with the camber kit, and they should know what to do.</TD></TR></TABLE>
thats crap. i hate depending on other people to get my ride going.
thanks for the write up. i know just what your talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLUDEnu &raquo;</TD></TR><TR><TD CLASS="quote"> shakes Im in the same boat as you! I bought a kit a few months ago from landspeed racing and It came with no instructions and like 100 parts. It is suppose to be ingalls so if you get it down will you do a write up? </TD></TR></TABLE>
yeah man, 4 boxes, no instructions. ill see what i can do about doing a write up. i will take a few pics at least but im on a time crunch and may not have the time to take enough pics for a proper write up.
Old Sep 14, 2004 | 02:43 PM
eLUDEnu
Guest
Posts: n/a
yeah man, 4 boxes, no instructions. ill see what i can do about doing a write up. i will take a few pics at least but im on a time crunch and may not have the time to take enough pics for a proper write up.[/QUOTE]
mine came in one box!
Old Sep 14, 2004 | 03:29 PM
user 9782082308's Avatar
Default Re: Installing Camber Kits (eLUDEnu)
For the fronts, take a pice of pipe thats bigger than the top of the balljoint and a piece of pipe that just fits over the bottom. Clamp in a vice untill the balljoint pops out. The camber kit balljoint should go in pretty easy. If it needs pressing in just use the kits main nut to sinch it into the control arm.
Lipan90crx
10
Aug 7, 2008 10:50 AM
roydogg
Dec 5, 2002 08:06 PM
dellman177
Oct 3, 2002 06:59 PM
.brad
Sep 9, 2002 11:41 AM
p0pe
May 22, 2002 06:30 AM
