Fuel problem?
Old Sep 9, 2004 | 06:06 AM
HaveNoLife's Avatar
Default Fuel problem?
I have a 2000 Prelude auto that I am returning back to stock from turbo. Problem is, I can't find my stock injectors. I am running Civic injectors just to see if it'll start up. Will Civic injectors work? I know they are smaller. So far, the car will not start. The fuel pump will pressurize in the on position, but will not pump when cranking. Is this a fuel pump problem? Relay problem? The car will start with carb cleaner in the throttle body. The Civic injectors came off of a running car.
Old Sep 9, 2004 | 09:13 AM
jackstands's Avatar
Default Re: Fuel problem? (HaveNoLife)
which civic injectors, most of them aren't compatible. search for injectors sizes. you'll find all the specs.
93accordmike
K Series
Mar 21, 2012 09:20 PM
L_K
Feb 23, 2007 05:31 PM
slamedcivic
Nov 2, 2006 02:49 PM
CLE
Jul 13, 2006 02:25 PM
