PLEASE HELP ME- i'm stranded
Old Sep 11, 2004 | 05:59 AM
Coelacanth's Avatar
Default PLEASE HELP ME- i'm stranded
I have an h23, 93 prelude that won't start. When i check the ECU fault code i get a light that stays on permanently, so does this mean i have a code0? The fault code light does not stay on when you try to start the engine. Any help anyone could give me would be greatly appreciated as I need this car to get me to work.
Old Sep 11, 2004 | 06:15 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: PLEASE HELP ME- i'm stranded (Coelacanth)
So you jumped the ECU because the car won't start?
I thought you only check for the code when you get a CEL.
Did you try jump starting the car? Does the engine even turn? It could be anything, we need more details.
Old Sep 11, 2004 | 06:46 AM
Coelacanth's Avatar
Yes the car turns over, all the plugs are fine and producing plenty of spark. The fuel pump is kicking out plenty of pressure and the injectors are injecting. Oh wait, I just heard an engine noise outside. The car just started, which is a bit of a mystery, its been dead for 3 days. Thanks anyway
Old Sep 11, 2004 | 11:27 AM
Coelacanth's Avatar
Car seems to be running fine now, if anything it sounds a little better (probably my imagination/relief), ECU still gives out a continuous light as its fault code (go figure). If anyone else has the same problem don't ask me how we fixed it, we've taken just about everything off and re-atached it.
P.S we didn't reset the ECU, we were just about to when it started again
Old Sep 11, 2004 | 11:37 AM
Quick99Si's Avatar
Uhmmm... code 0 = faulty ECU. Are you in limp home mode, with the rev limit at ~3200rpm? Because that generally indicated a fried ECU or improperly inserted chip.
If not, then I suppose it could be a bad ground or loose pin on the ECU connectors?
Adi
gnxpro24
Transmission & Drivetrain
Apr 21, 2011 03:16 PM
az90civic
Sep 7, 2007 08:05 AM
ANONYMOUSdeecee
Mar 7, 2007 07:47 PM
compwc18
Oct 19, 2004 05:01 PM
South Bay Surfer
Jan 25, 2004 04:33 PM
