Prelude taking a while to turn over
Old Sep 14, 2004 | 12:44 PM
dj626's Avatar
Default Prelude taking a while to turn over
My 98 prelude is taking a while to turn over. It does start everytime, it just takes longer than normal to actually start. Any suggestions? All the services and tune-ups are up to date. I did do a search and found tons of posts for preludes that won't start.. but not much in terms of the turn over.
Old Sep 14, 2004 | 12:55 PM
98TypeSH's Avatar
Default Re: Prelude taking a while to turn over (dj626)
Probably a battery issue. My did the same at first until the battery completly died. Put in a new one in, first time i touch the key it started like its in a hurry or something. Test the voltage on that beast.
Old Sep 14, 2004 | 01:49 PM
Hawkze_2.3's Avatar
Mine would take 5-6 turns every now and then, and then I found and fixed a small fuel leak (a line wasn't tightened all the way down), and now no problems.
Old Sep 14, 2004 | 02:04 PM
andeh22's Avatar
Default Re: Prelude taking a while to turn over (Hawkze_2.3)
possibly battery, possibly fuel leak. i notice when im low on gas it takes awhile to turn.
Old Sep 14, 2004 | 02:09 PM
BolivianFuego's Avatar
Default Re: Prelude taking a while to turn over (andeh22)
Could also be your fuel pump is just old. Put it in the second click of the key, and wait like 10 secs for fuel to run through the lines. Then start your car. If it starts off smoothly like nothing then its the fuel pump, and its just getting old. Thats all. If it isnt this then it might be what the other members have suggested. Hope i helped some what.
Old Sep 14, 2004 | 02:51 PM
kellyk75's Avatar
Default Re: Prelude taking a while to turn over (BolivianFuego)
simple check is to see if your battery terminals are clean. Pull them off though because sometimes they can look okay but have corrosion where you can't see.
Old Sep 15, 2004 | 12:48 PM
dj626's Avatar
Thanks for all the info guys. Battery was pretty old, bought a new battery. Starts up like new.
Old Sep 15, 2004 | 01:09 PM
98TypeSH's Avatar
thats the first thing i said
glad you fixed it for me
sl0waccord
Mar 3, 2012 03:13 PM
LSBeast
Jan 19, 2008 07:41 AM
gaydm
Mar 6, 2006 08:19 PM
EvilKokonut
May 30, 2005 08:54 PM
junya16
Mar 1, 2003 07:30 PM
