problem with restarting 97
Old Sep 10, 2004 | 01:29 PM
jayhan's Avatar
Default problem with restarting 97
for example, if I go to gas station. I turn my car off, and when I return a few minutes later, it will start and immediately die. I wait about a minute or two and then it will start as if nothing happened. If anyone has any idea what could cause this please let me know! Its kind of annoying! By the way, this is a base model 97 prelude. Thanks!
Old Sep 10, 2004 | 03:25 PM
limpmode's Avatar
Default Re: problem with restarting 97 (jayhan)
do you leave the key in the on position? like where it would be if the car is running?
Old Sep 10, 2004 | 03:58 PM
britishlude's Avatar
Could be a faulty ignition switch, common problem and there has been a recall by Honda on this, if you contact the dealer they will fit a new upgraded switch for free.
Old Sep 10, 2004 | 07:18 PM
esca's Avatar
search main relay...
Old Sep 10, 2004 | 09:49 PM
prelude1897's Avatar
Default Re: problem with restarting 97 (esca)
may need a new ignition switch. There was a recall on them, so you should just take it in have the dealership put a new one in for you
Old Sep 12, 2004 | 01:17 AM
jayhan's Avatar
Default Re: problem with restarting 97 (limpmode)
Yes, the key is still in the "on" position. I did find a post card in the glove box about that ignition recall. I dont know if previous owner had the work done, though. Does that sound like something the faulty ignition would cause?
Old Sep 12, 2004 | 01:21 AM
jayhan's Avatar
It only happens when I have been driving, though. It always starts on first try, as long as it has been longer than a few minutes after i turn car off.
Old Sep 12, 2004 | 01:27 AM
Monkey Fing a Coconut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayhan &raquo;</TD></TR><TR><TD CLASS="quote">Does that sound like something the faulty ignition would cause?
if it wasnt, then why would several people tell you it could be, its a recall, u should go get it replaced anyways before its too late otherwise that could be another problem, once its done, if it still happens, then work on it...listen to people here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by britishlude &raquo;</TD></TR><TR><TD CLASS="quote">Could be a faulty ignition switch, common problem and there has been a recall by Honda on this, if you contact the dealer they will fit a new upgraded switch for free.</TD></TR></TABLE>
Old Sep 12, 2004 | 01:42 AM
jayhan's Avatar
Default Re: problem with restarting 97 (twistedbydezign)
I am listening to people here, Im just asking if there is any thing else it can be. Per above, it can be a main relay OR the ignition recall. I was just asking if that was a comon reason to die after it started up fine.
Old Sep 12, 2004 | 10:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayhan &raquo;</TD></TR><TR><TD CLASS="quote">I am listening to people here, Im just asking if there is any thing else it can be. Per above, it can be a main relay OR the ignition recall. I was just asking if that was a comon reason to die after it started up fine. </TD></TR></TABLE>
In answer to above yes there are other things it could be, but if you get the switch done free at least you can rule that out and look at the other causes after, it's a process of elimination I'm afraid, and yes a faulty switch with dodgy contacts inside causes the car to die at anytime after start, when hot/cold and hopefully not while overtaking.
97ludajj
Sep 3, 2010 03:24 PM
Scarface31313
Apr 28, 2010 04:06 PM
GO-FIGHT-KILL
May 22, 2007 06:34 PM
Preludegirl
Apr 11, 2005 01:51 PM
wtfitzsoda
Jan 18, 2005 03:43 AM
