Rev Limit
Old Sep 14, 2004 | 11:54 AM
JDM00SI's Avatar
Default Rev Limit
Sup,
noobie here, but how do u find the max rev on ur car? do you just keep revving it or what? won't it bent valves etc if u go too high? Thanks
Old Sep 14, 2004 | 12:04 PM
JDM00SI's Avatar
Default Re: Rev Limit (bigbeasta4)
bump
Old Sep 14, 2004 | 12:08 PM
revlimitx04's Avatar
In an auto the rev limiter is slightly past the red line... what will happen when you hit it the car will bleed pressure off the block and automatically slow the car down.
Not a very good thing to hit the rev limiter...
if you hit it continiously it could cause internal damage
Old Sep 14, 2004 | 12:48 PM
JDM00SI's Avatar
Default Re: Rev Limit (revlimitx04)
so if u have a manual..just rev it..and when it gets to 7800 or watever...keep it there for lke 5 seconds and it will be my rev limit? Thanks
Old Sep 14, 2004 | 12:49 PM
98TypeSH's Avatar
dont take it any higher than 7200-7300 on the tach ok ? thats all there is to it. over rev it and you bend valves.
Old Sep 14, 2004 | 12:50 PM
JDM00SI's Avatar
Default Re: Rev Limit (98TypeSH)
but how do people determine the rev of thier car?
Old Sep 14, 2004 | 12:52 PM
98TypeSH's Avatar
stock fuel cut off is 7800 on the tach, that would be your rev limiter cheif. You can just ask for the spec. All h22's got the same unless they got an ecu flash/swap. damn. go rev the **** out of it then, i dont care. dont complain when your valves look like an "S" when you pull them.
Old Sep 14, 2004 | 12:54 PM
JDM00SI's Avatar
I don't rev the **** out of it, i just got it also..highest ive taken it is maybe 6800....just new and need the specs. I'm thinking about starting with a apexi n1 catback. what do yoou think of it?
Old Sep 14, 2004 | 01:11 PM
the-one1's Avatar
"but how do people determine the rev of thier car?"
Well, Honda gives birth to a motor, and they rev it till it dies, then they count 1K rpm under that and call it the red line with a big red line on the tach for you to see and admire going past it.
Old Sep 14, 2004 | 03:51 PM
Speedra500's Avatar
Default Re: (the-one1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the-one1 &raquo;</TD></TR><TR><TD CLASS="quote">"but how do people determine the rev of thier car?"
Where did you get this information?
Old Sep 14, 2004 | 03:59 PM
eLUDEnu
Guest
Posts: n/a
Default Re: (Speedra500)
I dont know but it is funny ****!!!
Old Sep 14, 2004 | 04:06 PM
Burte's Avatar
check out the locked post "prelude FAQ"by Honda318DX at the top of forum, one of the links is for the H22, if that doesn't work try doing a search....I'm sure this has been discussed before
Old Sep 14, 2004 | 04:13 PM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbeasta4 &raquo;</TD></TR><TR><TD CLASS="quote">so if u have a manual..just rev it..and when it gets to 7800 or watever...keep it there for lke 5 seconds and it will be my rev limit? Thanks</TD></TR></TABLE>
you put the car in neutral and you rev it as high as you can for 1 min. the longer you hold it at WOT, the more your ECU will compensate for higher revs. next thing you know, you'll be able to rev to 9k. *sarcasm*
umm...there's this link that's posted near the top of this forum called "FAQ FAQ FAQ - Essential Prelude Links" umm...if you check that link out...umm...maybe you'll learn a thing or maybe two...and umm...there's this other thing called the "search function"...
just incase you're feeling lazy(can't believe some people are), too blind too see it, or just plain too stupid to find it, here it is.
.: FAQ FAQ FAQ - Essential Prelude Links |::.
https://honda-tech.com/zerothread?id=689805
Search function
https://honda-tech.com/zerosearch
can't believe some people don't know how to use the search feature and the freakin FAQ's
Old Sep 14, 2004 | 04:48 PM
LockStock99Si's Avatar
The rev limiter is just a fuel cut, I wouldn't redline all day everyday but on Honda's you'll be fine
Old Sep 14, 2004 | 07:11 PM
the-one1's Avatar
I was kinda kidding in my earlier post. Like it has been mentioned and whill always be mentioned about rev limits: Its there for a reason. Machines can only move so fast until the machanical parts can no longer conatain the forces acting upon it, then it breaks. Piston engines can only rev so high, roatary on the other hand are different.
Old Sep 16, 2004 | 10:28 PM
Speedra500's Avatar
piston engine can only rev so high eh? of course but some rev to nearly 20,000 rpm while some redline at 5,000 and obviously there is alot of differences in these engines. Friction and weight are the main determining factors of this. Higher pistons speeds would obviously induce more friction and create more heat and more stress of rings and ring lands, higher speed and weight put increased force on the rotating assembly and also harmonics come into play when taking an engine to rpm range that it was not designed for.
Old Sep 17, 2004 | 03:32 AM
the-one1's Avatar
Of course piston engines can rev to 20,000 rpm. One of mine can rev to 35,000 rpm, but thats only 2.5cc nitro methane.
Old Sep 17, 2004 | 11:36 AM
JDM00SI's Avatar
k i understand specs etc...
but when someone upgrades thier cams or some internals in order to make thier rev higher...how do they determine thier new highest rev?
thanks
Old Sep 17, 2004 | 01:14 PM
the-one1's Avatar
I like to know that too.
Lets say I got some magic pistons weighing 1 oz. and a magic crank and rods and a whole new crankshaft from Magic Corp Motors.
What determines my rpm limit now with out blowing it up,? J/W, no flames.
KpaTyH
10
Feb 28, 2010 01:52 PM
vi3t00si
Apr 26, 2006 09:32 PM
04Sispeed
Apr 25, 2005 04:10 AM
AdamITR
Jul 7, 2001 06:35 AM
