abs wheel sensor,
Old Sep 12, 2004 | 01:41 PM
ludiferino's Avatar
Default abs wheel sensor, install + availability q's
So, my abs light came on while driving around today. I jumped the connector, and read the code, and found it to be front right wheel sensor from the Helm's manual. I didn't have time to go through the flow chart checking resistances, so I just assumed it's the sensor. It's on a 93 vtec, so I assumed that with an 11 year old car these sensors will go bad.
I'm wondering if this is something I should attempt myself, or pay someone else to do?
I went to majestic honda's website looking for a part number and price but came up with nothing. So if you think I can/should play with the abs, where can I get this part (besides the local Honda store, I don't like dealing with them)?
Thanks in advance. And I did search, which told me the stealership shouldn't charge me more than $300 for the sensor and labor.
Old Sep 13, 2004 | 08:57 AM
ludiferino's Avatar
Default Re: abs wheel sensor, install + availability q's (ludiferino)
So, is it safe to assume that this should fix should be left to teh hands of a dealer?
Old Sep 13, 2004 | 11:31 AM
cyco's Avatar
i got the same code on my lude ('96 si). i actually bought another sensor from someone on this forum and replaced it. no prob. thing is it didn't fix the prob. it still gave me the same error code on the same wheel. it's been like that for a couple years now ... drives fine but i just have to remember that i gots no abs...
Old Sep 13, 2004 | 12:23 PM
ludiferino's Avatar
Default Re: abs wheel sensor, install + availability q's (cyco)
Hmmm, I hope that doesn't happen to me. I still need to get my hands on a multi-meter to check the continuity of the wiring. I hope a broken wire or out of position sensor is the real problem, those are virtually free to fix.
Hondaman56
Sep 21, 2012 07:44 PM
HondaHeddie
Sep 29, 2008 08:02 AM
citrus3000psi
Oct 26, 2005 03:47 AM
Dirt
May 22, 2002 12:38 PM
