Wierd Idel Problem - - - Need Help
Old Sep 13, 2004 | 08:31 PM
Red Rocket's Avatar
Default Wierd Idel Problem - - - Need Help
Hey i just installed my h22 back in my car after having it fully rebuilt all motor... i dubble checked that all the sensors and they were all pluged in and i checked all the vacume lines too and they were all properly conected.
Here is my problem i started it up for the first time and it fired up first time but i let it run for a few secs and then it started to rev to about 3000 rpm then fall all the way down to the point were it almost stalls but everytime it dropped it gave me an engine light and it went out when the revs shot back up...and it did that about 3 or 4 times then the car just stalled.
Can anyone help me out with any suggestions or has anyone had the same problem
Thanks Alot
Old Sep 13, 2004 | 08:48 PM
Freemantle's Avatar
Default Re: Wierd Idel Problem - - - Need Help (Red Rocket)
What is "built full motor?"
Any engine management?
"lean-miss" sounds?
IM/TB adjustments?
Old Sep 13, 2004 | 08:56 PM
Red Rocket's Avatar
Default Re: Wierd Idel Problem - - - Need Help (Freemantle)
fully built
- type s pistons
- skunk2 valve train
- skunk2 stage 2 cams
- port & polish
- 5 angle valve job
- crank micro polished
- everything blueprinted & balanced
and no real engine management right now just a fpr but soon to go with hondata
do u think it might be the icv or tps or even the map sensor
Old Sep 14, 2004 | 06:41 AM
kellyk75's Avatar
Lots of stock preludes have this problem. It is usually the egr valve (Exhaust Gas Recirculation).
Zaraki
15
Dec 30, 2008 01:41 PM
00ls1
Aug 4, 2008 09:37 PM
93ludesitec
Jul 11, 2007 07:40 AM
VanHonda
May 6, 2004 08:57 AM
