question about gas
Old Sep 13, 2004 | 06:02 PM
darockjc's Avatar
Default question about gas
I did a search and couldnt find anything about the h22. I have a 2000 h22a4 in a 94 accord. I have supertech valves, valve springs and retainers and also stage 2 crower cams. Just wondering what octane i should run. I figure i should run 91 or 93. Also is 100 octane to run to high. Thanks for the help?
Old Sep 13, 2004 | 07:05 PM
red92si's Avatar
You should most definately be running premium gasoline. Are you still running the stock compression?
Old Sep 13, 2004 | 07:13 PM
2lude4u's Avatar
Default Re: question about gas (darockjc)
With stock compression 10:1 you should be using 91 octane. Jdm 10.6:1 and type S 11:1 will do okay on pump gas . After that it's something like every .5:1 gain in compression can use an extra octane.
Old Sep 13, 2004 | 07:34 PM
darockjc's Avatar
Default Re: question about gas (2lude4u)
yeah stock compression basically. The valves added a very little bit of compression b/c i switched from domed valves to flat valves.
silverskateEF9
Sep 3, 2007 01:36 PM
mfisher1967
Honda Civic (2006 - 2015)
Jun 18, 2007 09:45 PM
norcalbayboy
29
Aug 7, 2006 10:08 PM
limpy
Jun 27, 2005 01:04 AM
Kev95lx
Dec 7, 2002 12:37 PM
