Prelude Starting problem!
Old Sep 9, 2004 | 11:29 PM
wilrock's Avatar
Default Prelude Starting problem!
sometimes i dun realize i didnt have the clutch all the way down when i try starting my car..it doesnt start...then i try again but this time pressing clutch all the way down..then my car wont start for like 5 minutes...it would jus keep cranking...does anyone know why?!??! thanks
Old Sep 10, 2004 | 12:27 AM
esca's Avatar
Default Re: Prelude Starting problem! (wilrock)
any more info? it might be your main relay.. or even your fuel relay?
at what temperatures do you start it?
Old Sep 10, 2004 | 11:30 AM
collije's Avatar
Default Re: Prelude Starting problem! (esca)
Flooded your engine with gas?
Old Sep 10, 2004 | 01:06 PM
jlv55's Avatar
Default Re: Prelude Starting problem! (collije)
cant flood a honda like that.
Old Sep 10, 2004 | 03:14 PM
delguiner's Avatar
Default Re: Prelude Starting problem! (klutch44)
guaranteed to be the main relay
Old Sep 11, 2004 | 04:06 PM
wilrock's Avatar
Default Re: Prelude Starting problem! (delguiner)
how should i fix it?
Old Sep 12, 2004 | 07:41 PM
delguiner's Avatar
get a new main relay!
i dont know how to do this, but ive heard about this problem soooooooooo many times!
and its always been the main relay
good luck dude, and give us the results!
Old Sep 12, 2004 | 08:52 PM
eric416's Avatar
i have a similar problem but it usually happens when the car stalls in 1st gear, i have to wait a few min before it starts again.
Old Sep 13, 2004 | 04:52 AM
DarkBB4's Avatar
Default Re: Prelude Starting problem! (eric416)
um.. sometimes my car does that....
just hold t he clutch in.. put it in First.... then let out the clutch......
Then put in the clutch and try tostart it again
Old Sep 13, 2004 | 08:21 AM
Filthy Focker!'s Avatar
Default Re: Prelude Starting problem! (DarkspeedVtec95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner &raquo;</TD></TR><TR><TD CLASS="quote">get a new main relay!
good luck dude, and give us the results! </TD></TR></TABLE>
Don't wan't to **** on your parade but, how can you be so sure about this when you have not even experienced this problem in the first place? If you can diagnos problems like this simply by reading HT, damn, i could use a guy like you in the shop...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilrock &raquo;</TD></TR><TR><TD CLASS="quote">sometimes i dun realize i didnt have the clutch all the way down when i try starting my car..it doesnt start...then i try again but this time pressing clutch all the way down..then my car wont start for like 5 minutes...it would jus keep cranking...does anyone know why?!??! thanks</TD></TR></TABLE>
Nee dmore info... Describe a bit more.
fs
Old Sep 13, 2004 | 08:31 AM
98TypeSH's Avatar
Default Re: Prelude Starting problem! (filthy_shovel)
i dont quite understand your question.
It starts fine if you push the clutch in correct???
Old Sep 14, 2004 | 05:26 PM
wilrock's Avatar
it doesnt start when i dont push in the clutch correct...then right after..i do push it in correct and try starting but the car wont start for like 5 minutes..it just keeps cranking...
Old Sep 15, 2004 | 06:26 AM
delguiner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">
fs</TD></TR></TABLE>
Your absolutely right, and i shouldnt have said i guarantee thats the problem... But recently ive seen a lot of ppl having problems starting their car... my brother had that problem with his 91 SI, so i was thinkin maybe you have the same problem!
jimmy o.
Jul 23, 2011 08:23 AM
oakpwr
Jan 20, 2007 12:05 PM
silentblackhat
Jun 10, 2005 07:55 PM
fe519
Sep 17, 2003 04:34 AM
