crower cams
Old May 11, 2005 | 09:37 AM
lude of pre 2.3's Avatar
Default crower cams
i have the crower cams and springs and retainers how should i go about tuning it? one of my buddies owns his shop in town he said we might be able to remap a b series computer and use it for my tune. Also would a mega squirt work on my stock computer its a 92 h23
Old May 11, 2005 | 10:34 AM
high_revs's Avatar
iwould tune it on a p06 or ls ecu with uberdata.....what stage did you get?
Old May 11, 2005 | 11:00 AM
Default Re: (all mOtor h23)
i got the stage 2 3/4 race all motor cams-62482-2 and im rebuilding the motor to stock specs and porting and polishing the head hopin for 200 whp with a good tune
Old May 11, 2005 | 11:06 AM
high_revs's Avatar
im looking for around 200whp also...but your gonna need more then stock compression.
Old May 17, 2005 | 01:01 PM
na no more compression just a little nitrous pry a 50 shot and if that holds well ill pry give it a 75 at the track with some mix race gas. wet shot only
Old May 17, 2005 | 02:07 PM
SUB-0 H23's Avatar
Default Re: (lude of pre 2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude of pre 2.3 &raquo;</TD></TR><TR><TD CLASS="quote">na no more compression just a little nitrous pry a 50 shot and if that holds well ill pry give it a 75 at the track with some mix race gas. wet shot only</TD></TR></TABLE>
that sounds like a good plan, good luck w/ that
the only thing is that you are not going to get the most out of those cams w/ the h23's relatively low comp., b.t.w. you could of run a 11:1 comp. w/ a 50 shot of nitrous ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all mOtor h23 &raquo;</TD></TR><TR><TD CLASS="quote">iwould tune it on a p06 or ls ecu with uberdata.....what stage did you get?</TD></TR></TABLE>
or hondata
sean-sports
Jul 15, 2007 11:55 AM
vestalfootball72
Oct 25, 2006 09:39 AM
NirVTEC
Feb 17, 2004 10:38 AM
mike5809
Dec 15, 2003 11:59 PM
Mike K
Mar 1, 2002 03:22 PM
